RPM surges when clutch is engaged but car is in neutral.
Old Aug 1, 2006 | 10:33 AM
chr1s's Avatar
pwn*
Question RPM surges when clutch is engaged but car is in neutral.
This just started happening yesterday morning. I've searched and read up on the "cold oil causes the crank to turn blah blah blah" But this is texas, and it's 97 degrees in my freaking garage, the oil is probably warm enough. All of the problems I saw with cold oil were in the winter. On to the issue!
This only appears to happen when the engine is cold. I start it, and if I take my foot off the clutch, the RPM's start to surge between 1750 and 1250 RPM's. If I disengage the clutch, the surge stops. My car does not move during the surges.
This behavior occurs whether I have the AC on or off. There doesn't seem to be a problem once the engine is warmed up.
Could the problem be my clutch needs to be adjusted? I was thinking that when the clutch is engaged it's touching just enough to cause the engine to sputter (thankfully the computer catches it in time), but not enough to move the car.
Any ideas before I take it into the dealer? I'm comfortable around cars, and I'd like to avoid a trip to the dealer if I could.
Old Aug 1, 2006 | 11:32 AM
chr1s's Avatar
pwn*
Ok well I called the dealer and I'm taking it in.
Old Aug 1, 2006 | 11:37 AM
zoom44's Avatar
neutral switch
Old Aug 1, 2006 | 01:23 PM
chr1s's Avatar
pwn*
explain?
Old Aug 1, 2006 | 07:27 PM
Originally Posted by zoom44
neutral switch
bad.
zoom check pm..
tell the dealer to check the switch... it is likely going bad.
Old Aug 1, 2006 | 08:03 PM
zoom44's Avatar
the tranny/shifter one not the clutch switch
Old Aug 2, 2006 | 09:59 AM
chr1s's Avatar
pwn*
so I typically like to learn about these kinds of things. Please explain what a neutral switch is and what it does.
lucy! joo gots some splainin todo!
Old Aug 2, 2006 | 10:57 AM
zoom44's Avatar
it tells the TCM that the car is in neutral so the TCM can send a signal to the PCM and it can go into idle mode. if one doesnt happen neither does the other and the PCM gets confused about what it is trying to do. garbage in garbage out
SOVINE's Avatar
Whenever I start my car in the morning... mine surges to about 1500 rpm, but within about a 20 seconds it calms down. So... aye dunno im not losing any sleep over it or endure the hassle of not having my vehicle for 2 days.
Old Aug 2, 2006 | 11:00 AM
chr1s's Avatar
pwn*
gotcha! thanks!
Thanks for your comment, but this isn't normal.
Old Aug 2, 2006 | 02:14 PM
chr1s's Avatar
pwn*
well naturally it didn't do it for the dealer. He wants to keep my car one more day to try and start it again tonight and then once more in the morning to see if there are any issues.
On the upside, he did offer me transportation, I didn't need it, but it was a nice gesture.
Also, they said they didn't have the newest flash yet.
Old Aug 2, 2006 | 02:20 PM
Unhooked's Avatar
mine does the same thing in the morning, it'll go upto 2K and then within a few seconds go all way down to 900RPM. This is normal as far as I know
Old Aug 2, 2006 | 02:26 PM
zoom44's Avatar
yes thats part of the engine programming since 2-3 flashes ago
Old Aug 2, 2006 | 02:29 PM
zoom44's Avatar
incorrect- he would be getting a call by now asking why he hasnt pinged the server. he's 3-4 update levels behind if thats true. incompetence !
Old Aug 2, 2006 | 02:51 PM
chr1s's Avatar
pwn*
so you wanna call hiley mazda and raise a fit for me? You seem to be "in the know"
<3
Here's the number:
800-863-0619
Old Aug 2, 2006 | 03:07 PM
zoom44's Avatar
christ hiley should know better
Old Aug 2, 2006 | 03:12 PM
chr1s's Avatar
pwn*
yeah they seemed to be pretty good when I had some other work done there. Don't know what the problem is.
Should I call them in the morning and request a certain flash? or what?
Old Aug 3, 2006 | 03:30 PM
chr1s's Avatar
pwn*
hiley gave me a new flash. "N3Z2-18881-S". horray!
Old Jul 4, 2023 | 03:13 AM
FullSenderBender35's Avatar
Hey did anyone figure this out yet....im currently going tbru the same exact thing....replaced the nuetral switch and same thing....surges everytime i press the clutch....and when i started it it had a fair amount of white smoke only if I rev tho
Dokuji
Nov 1, 2016 02:51 PM
thewatcher101
Aug 4, 2015 10:42 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
yapakanichi
Jul 21, 2015 07:41 PM
Belalnabi
Jul 17, 2015 07:48 PM
