E-manage Ultimate v2.00 released
Old Jul 29, 2006 | 09:37 PM
mikeschaefer's Avatar
I wanna rock! Rock!
http://www.mohdparts.com/emanage/ind...20&%20Firmware
I Just glanced over it and only thing new i see is freakin tool tips! But that's cool I couldn't tell what the buttons were for at first.
Old Jul 29, 2006 | 09:42 PM
mysql101's Avatar
I've had 2.0 for a few days now... with the previous version I would sometimes see the maps light up in random areas where it shouldn't be. e.g; at idle, sometimes I'd see 6,000 rpm light up.
Old Jul 29, 2006 | 10:49 PM
MazdaManiac's Avatar
Hmm, I wonder how Mohd got that?
Its not even available, yet.
Old Jul 29, 2006 | 11:04 PM
mysql101's Avatar
lol. he must be a hacker.
Old Jul 30, 2006 | 09:36 AM
Or a friend...
Old Oct 24, 2006 | 05:05 PM
I wanna rock! Rock!
Well now that it's REALLY released... anyone have any comments?
Old Oct 24, 2006 | 05:25 PM
mysql101's Avatar
yes, you be the first to upgrade. I'll wait and see if your car starts to catch fire.
Old Oct 24, 2006 | 06:26 PM
It works.
Old Oct 24, 2006 | 08:05 PM
I wanna rock! Rock!
I would... but it won't do any good until my turbo is installed. I'm taking 2 weeks leave starting next week and I'll do it then. My dad's got the o2 bung welded and the compression pipe tapped for the #2 fix. All I need now is the BOV flange welded... well... and I'd like to have the derwankel gauge pod but I guess I can just have the gauges laying in the void left by taking out the dash piece... for now anyway.
Old Oct 25, 2006 | 04:50 PM
I wanna rock! Rock!
There is now an option for the INNOVATE AF meter under the Front Panel tab under A/F meter. Its range is from 7.35 to 22.39 though. MM your file has 8.50 to 22.40 for your LC-1. Should I sweat it?
Old Oct 25, 2006 | 05:12 PM
You can set up your LC-1/LM-1 to whatever range you want.
I have the range in the EM2 file set up for how I have my LM-1 set up.
They need to match, however you do it.
Old Oct 25, 2006 | 06:27 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
I am not seeing the option for the Innovate A/F Meter. I see NGK, HKS, Blitz, ect... but not the Innovate. I downloaded the executable and installed 2.0 last night and it said everything completed normally. Any suggestions as to why I don't see the Innovate option?
Old Oct 25, 2006 | 06:45 PM
tdiddy's Avatar
Never mind. I uninstalled everything then reinstalled it and I can now see the Innovate A/F option.
Old Oct 25, 2006 | 08:51 PM
I wanna rock! Rock!
gotcha thanks, I read too fast and skipped over the phrase "factory default"
Old Nov 11, 2006 | 08:23 AM
C_RX8's Avatar
mikeschaefer, hey bud let me know how it goes with the 2.00 update...i am currently going to tune a base map that I have on my EMU because it is making my car run lean at idle....(15.2-.5)....then it spikes higher than that.....needless to say I took it to a shop and the dumb *** and or myself for taking it there and trusting them with my car .....they said they would tune the car but everything I took it they were like that software that is online does not interact with your EMU. I said beep beep and now I am taking it to a guy that rebuilt a renesis motor and put a greddy turbo kit and tune it to run properly.
Old Nov 11, 2006 | 08:27 AM
C_RX8's Avatar
Oh yeah, I finally realized that the real solution is a better and far more advance fuel management. Interceptor x is one right now, but anyone have true insight and knowledge of what HKS is running on their HKS RX8?
Old Nov 11, 2006 | 11:27 AM
mysql101's Avatar
There is no load on the engine at idle. 15.2 to 15.7 is where my car idles too. Without load, this AFR range is perfectly fine - in fact the leaner it is, the less fuel you're blowing out and wasting.
The EMU should only be activated when it senses pressure over 0 PSI (according to the map settings)
Old Nov 11, 2006 | 12:04 PM
I wanna rock! Rock!
yea a lean idle is rough but a rich one is stinky and wastes gas
can't do much about it with the EMU, that I know about anyway
Old Nov 11, 2006 | 12:09 PM
mysql101's Avatar
My idle at 15+ afr was not anymore rough than a stock cars. I think C_RX8 was thinking 15 was out of the "safe" zone, and thus thought it was a problem. It's all good
Old Nov 11, 2006 | 06:21 PM
C_RX8's Avatar
mysql101, did you sell your EMU? Thanks for all the insight.....by the way, do you still have your BOV recirculated?
THanks a bunch!
Old Nov 11, 2006 | 06:26 PM
mysql101's Avatar
THanks a bunch!
I'm in the process of selling it (I have a FS thread in the parts forum). There's no local tuners that do much with EMU that I know of. And Mazsport is less than 30 miles from my house, so interceptor-x was the route I took.
BOV was recirculating, but I took that off once I installed the int-x.
Old Nov 11, 2006 | 06:32 PM
C_RX8's Avatar
I found a guy that worked on an RX8 back when it was the emanage blue and he got it to run right. Now this guy is going to tune my EMU to fix any LTFT and STFT and any other bugs. He is also going to set it to vent atmospheric. THe only problem I truly had is when it would die when I put it in neutral when I was driving like 30 mph and so forth.....then most of time I come to a halt and it would idle fine then act like it was going to die or stall.......the RPMs was about 900 and then dip to 300 and go back up to 900......Gotta love it though! DO you have this problem right now?
Old Nov 11, 2006 | 06:35 PM
I wanna rock! Rock!
what about the pop pop?
Old Nov 11, 2006 | 06:53 PM
C_RX8's Avatar
yeah...might pops pops.... a whole lot too!
Old Nov 11, 2006 | 06:56 PM
mysql101's Avatar
when I set my bov to recirculate, the car quit making the popping noises.
I had a problem with idle for a little while, I think it was caused by a vacuum leak.
