View Full Version : Weird DTC Code
boonyloh
07-26-2006, 08:36 PM
I had a code scanner to check out the CEL light on the car..... wierdest thing is that i return with a DTC P0353 and P0354 Which is not in the workshop manual.
According to the generic DTC codes Both P0353 and P0354 = ignition coil failure
I'm a bit confused here...
Physical sympthoms are hesitation after 7000k with sudden power coming on and off. loss of power below 3000k
someone have an idea what's going on?
zoom44
07-26-2006, 08:39 PM
the scanner is not fully rx-8 compliant so you are gettign a generic code. you probably have a burn tcoil or two. try swapping the coils between leadign and trailing. let us know if you can feel a difference
titaniumgr3y
05-16-2007, 01:54 AM
I have the same problem.
I checked it with a scanner and it says for my coils a & c and i rechecked after clearing, and it gives a problem again 2 days later with the scangauge now, the P0353. i think are my coils.
