Warning Lights/All ON
Old Jul 22, 2006 | 10:52 AM
nace0088's Avatar
nace0088
My brake light,engine light,air pressure light have come on and remain on at all times.The DSC is also not working.It is affecting my steering.Has anyone experienced this.It just suddenly started happening.I'm going to take it to the dealer this week to have it checked out.Does anyone have any suggestions?
Old Jul 22, 2006 | 01:18 PM
Go48's Avatar
Of course, the DTC codes can be read from the PCM to determine the cause(s) of the idiot lights illuminating. The dealer can obviously do this or an auto parts store might be able to read the codes if they have an OBDII CAN-compatible scanner. Try AutoZone.
However, if you recently worked on the wheels or installed aftermarket wheels, could be you screwed up (very technical term) one or more sensors such as a TPMS or ABS sensor.
Old Jul 28, 2006 | 11:22 PM
I have that problem every time I go to start the car .......... all the warning lights come on..
Old Jul 28, 2006 | 11:37 PM
Student Driver
Does your remote still work? How about the interior lights?
Do you have aftermarket interior lights?
Check your fuses in the drivers kick panel...
Disconnect your battery for 30 mins and reconnect...
This will clear your computer and everything "may be" ok...
SUKIEE
Oct 9, 2017 09:41 PM
drlubell
Sep 26, 2015 11:58 PM
Rx8_412
Sep 24, 2015 08:51 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
