Widest Rims and Tires
Old Jul 21, 2006 | 01:01 AM
SupraBrian's Avatar
For a staggered setup. What is the widest rim and tire you can fit on the rx-8 in the front and rear.
Im coming from the supra scene, and we usually keep to 295-315s in the rear, and 255-285s in the front.
Could i pull this off in an Rx-8?
thanks,
brian
Old Jul 21, 2006 | 01:37 AM
DOMINION's Avatar
I don't buy Kool-Aid
Supras rule!.
Try searching around. Some guys have 20 X 10 or 20 X 9.5 however you might want to roll your fender for that kind of set up.
You must be going for show right?
The stock off set is 18 X 8=50mm.
I'm going with 18 X 8.5 in the front and 18 X 9.5=35mm in the back or 19 X 8.5 and 19 X 9.5 with Toyo's and Tein
Old Jul 21, 2006 | 02:23 AM
ElusiveFX's Avatar
8B8B8B
thanks,
brian
Brian,
You sound like me when i first came into the Rx-8 scean, from the Bmw's to the Vette's i was quite disapointed but then again were' not driving cars with over 400hp...
Most wheel manufactures such as DPE HRE and iForged, all custom 3-pc wheels recomend going with 19x8.5 and 20x10 ou
t back! although thats not all that wide in the front or the rear you'll be able to run a 245/285 setup...
Tab-
Old Jul 21, 2006 | 10:34 AM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
There are some guys on 18X9.5 with 285-30-18 front and rear. You might be able to go a little bigger on the rear, but I don't see a 315 fitting in the rear with out some work.
Old Jul 22, 2006 | 11:47 PM
ElusiveFX's Avatar
8B8B8B
Your right, i saw an 8 today running 275's on 9.5" wide wheels it looked absolutely gorgous...
Old Jul 23, 2006 | 12:49 AM
DOMINION's Avatar
Yup 19's X 8.5 & 9.5 baby!
Old Sep 14, 2009 | 01:05 PM
NOTURX8's Avatar
I'm having a bit trouble myself trying to figure out this jejeje...
I have GFG Wheels 8.5 in front and 10.5 in the rear with an offset of 35, so I'm asking what can be done besides the OEM adjustable cambers that wont go anymore negative.
I've rolled the fenders a bit, but it still didn't help
The tires stick out 1 1/4 and from what I see in the inside I can still push the wheel 3" more inside to avoid it from hitting the rear fender body.
Old Sep 14, 2009 | 01:58 PM
Wasn't Teamrx8 running 18x10" all around?
Old Sep 14, 2009 | 02:21 PM
tubingchamp's Avatar
What mawd bug?
I've got 275 18X9.5 all around.
Local source tells me you can get upto 295s in there. No need, though..
Old Sep 15, 2009 | 10:13 AM
nuke0907's Avatar
Never Blend In
nope. he sold his wheels to danobre. i have the same size and offset though.
18x10.5" +43 with 265/35/18 all around. no rubbing and no fender mods required.
Old Sep 15, 2009 | 12:13 PM
What mawd bug?
Pretty sure Dan's got 275s ATM.
Maybe even 285? Who knows, he has like 5 sets of tires in his garage.. Lol
Old Sep 15, 2009 | 12:45 PM
NOTURX8's Avatar
wow 285... now that's aggresive, and I thought I was the only retard with 275 settings jaja lmao... oohh well
Old Sep 15, 2009 | 03:56 PM
nuke0907's Avatar
Never Blend In
i wish i would have gotten 275's now. there is plenty of room for them.
Old Sep 15, 2009 | 03:57 PM
ZumnRx8's Avatar
RX8 & RX7 owner
^-fail
Old Sep 15, 2009 | 04:03 PM
nuke0907's Avatar
Never Blend In
^-jealous.
Old Sep 15, 2009 | 09:56 PM
Demon8's Avatar
Bump...
Old Sep 15, 2009 | 10:05 PM
Atilla's Avatar
I am THAT guy
jeezus...thread bump from hell...06'??
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
