NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
Help Deflooding
Old Jul 20, 2006 | 03:12 PM
OBTIQ's Avatar
>> Motion
Help Deflooding
Is There Anyone In The Nassau Area Willing To Help Me Deflood My Engine, I've Tried The Steps Online But Still Hasnt Worked For Me Yet, Maybe Im Doing Somethen Wrong
Old Jul 20, 2006 | 03:49 PM
expo1's Avatar
He's as bad as Can
Your try this?
https://www.rx8club.com/showpost.php...8&postcount=11
Old Jul 21, 2006 | 07:55 AM
Kel Rx8's Avatar
if your not 1st your last
if I was closer (N. NJ)I would help ya out
if you reach me on AIM I can try to work you thru it
good luck.
Old Jul 21, 2006 | 09:03 AM
OBTIQ's Avatar
>> Motion
thanks, I've done that step and the other DIY and no luck yet, I had a couple times with a huge hint of power but then it died down
Old Jul 21, 2006 | 09:14 AM
"Shanika"'s Avatar
#382
Did you or didn't you call Mazda Roadside Assistance to pick up your car?
"well i asked for an alternative to the DIY thas posted basically, and im fed up with it so I called mazda roadside to pick it up, im just assed out because im not under warranty anymore. Only good news is that this isnt the first time it's happened to me so I dont have to worry about getting a new battery."
https://www.rx8club.com/showthread.p...ight=Worst+day
Old Jul 21, 2006 | 10:41 AM
Kel Rx8's Avatar
HINT:
1.When it starts to die down start pumping the gas
2. and try to boost the car while cranking.example with another car giving you a battery boost.get ready for a cloud so out of garage would be nice so it doesnt get inside your home.
Old Jul 21, 2006 | 10:46 AM
Bart!'s Avatar
RAWR!@#
Remove your drivers side tire. Remove your spark plugs. Get inside the car, start cranking for a couple of seconds. Get out of the car. Put in your spark plugs. Start the car.
Bart!'s Avatar
RAWR!@#
Put on your tire.
Old Jul 22, 2006 | 11:22 AM
OBTIQ's Avatar
>> Motion
I tried that as well, I even cleaned the spark plugs also, but still nothing......
But my car is at the dealer waiting to get worked on, and called Mazda usa to see if they can assist me in anyway....
realized last time my car was at the dealer because it was hard to start they were suppose to install the new spark plugs and a different voltage batterym instead they replaced me witht he same one, so i'll see where all my bitchin' can get me, hopefully mazda will at least fork out half
Old Jul 22, 2006 | 03:14 PM
chrism's Avatar
Misfit Moderator TnC
that suxks...they should be covering it even it your over the miles
Draken
Sep 21, 2015 06:14 PM
wanted797
Aug 26, 2015 11:24 PM
rx8wankelrotary
Aug 17, 2015 10:42 AM
Davey's RX-8
Jul 28, 2015 12:13 PM
marc2820
Jul 26, 2015 10:47 PM
