Greddy Turbo Hose Routing
Old Jul 19, 2006 | 10:44 PM
KJ238's Avatar
Air + Fuel + Spark = Boom
I just want to get some input on the 3 hoses that was supposed to be connected to the intake. The way greddy meant it was:
Airinx filter ===> Jet Air Fuel Mixing Hose
air intake pipe (nipple 1) ===> Oil Fill
air intake pipe (nipple 2) ===> Metering Oil Pump Hose
There is a complication in which the fitting that was supposed to connect to the Jet Air Fuel mixing hose to my airinx was lost....
This is how my hose setup is when it came from the installer:
air intake pipe (nipple 1) ===> catch can
catch can ==> tee
tee => oil fill
tee => another tee
2nd tee ==> Jet Air Fuel Mixing Hose, Metering Oil Pump Hose
air intake pipe (nipple 2) ===> Sealed off
Just want to know whether there is any negative effects by running this...
Coincidentally i tried rerouting the hoses a different way
catch can ==> oil fill
air intake pipe (nipple 2) ===> tee
tee => Metering Oil Pump Hose
tee => Jet Air Fuel Mixing Hose
This routing method produced a better response, but it blasted white smoke through the exhaust whenever the car idled for more than about 10 seconds..... So i put it back to what the installer put it at....
It is my intention to put it back to the way greddy meant it, just wanna get your opinions whether this is correct:
Catch can ==>oil fill
Jet Air Fuel Mixing Hose ===> a breather
You think i will still get white smoke if i swap it to this route? Just want to get some input for fear of damaging my turbo...
Old Jul 19, 2006 | 10:45 PM
KJ238's Avatar
For Reference:
https://www.rx8club.com/showthread.p...bo+white+smoke
Old Jul 19, 2006 | 10:52 PM
rkostolni's Avatar
This should work fine. I don't know how many miles are on your turbo, but if it still smokes in this configuration, it is possible you have a blown oil seal.
Don't forget the check valve on the jet air fuel line.
Old Jul 19, 2006 | 11:06 PM
KJ238's Avatar
Check Valve? I dont think there was a check valve... The hose is 9mm, i dont think i've seen a check valve that size...
Old Jul 20, 2006 | 01:49 PM
rkostolni's Avatar
Originally Posted by GTAW
EDIT: you don't need the check valve
Without it you will have a small boost leak though.
Old Jul 20, 2006 | 08:56 PM
KJ238's Avatar
So now i get a 10 nipple... and fit it in there?
Or do i stick with the breather...?
has anyone done this rerouting of the hose?
What about the intake manifold plate... has anyone done it?
Old Jul 20, 2006 | 09:13 PM
two rotors's Avatar
I have the engine breather Td to the Jet Air with a check valve on the Jet air side.I will post apicture if you need it.It works fine.
Old Jul 20, 2006 | 09:14 PM
two rotors's Avatar
Oh yes the check valve came off a Turbo II.
Old Jul 20, 2006 | 09:33 PM
two rotors's Avatar
Hoses
Here's the picture.
Old Jul 20, 2006 | 10:14 PM
KJ238's Avatar
I dont really understand where you hose is going or why it is teed at that point
Old Jul 21, 2006 | 03:11 AM
KJ238's Avatar
I moved the jet air line to a breather... and out came the white smoke...
I am almost positive i took the right hose, what happens if it's the othery way round?
Should i just put it back to the way it was?
Old Jul 21, 2006 | 03:44 AM
SUPERMAC's Avatar
it would be nice if someone could provide a nice illustration of a hose routing diagram for turbocharging the 8. that would solve a lot of these "how and where to route hoses" questions
just my 2cents. im also having hose routing issues with my turbo setup.
thanks,
chris
Old Jul 21, 2006 | 10:50 AM
KJ238's Avatar
Jet air fuel hose
With the breather = white smoke...
With the hose connected to an inlet in the pipe... = white smoke...
Attached is a picture of the setup i tred... I already put it back to what it was before, coz i need to drive the car....
Any idea what could be the cause?
Old Jul 22, 2006 | 07:20 AM
two rotors's Avatar
Consider the functions of the pipes:
-the engine breather hose is taking any vapours out of the motor when they are above atmospheric pressure and so preventing pressure build up,
-the jet air pipe provides air at about atmospheric pressure to nozzles in the inlet port the purpose of which is to improve fuel atomisation at low engine speeds,
-the oil injection air provides air at atmospheric pressure to the inlet of the oil injector nozzles--the purpose being to prevent a vacuum getting to the oil supply.The reason being that if you do not break that vacuum you will suck oil into the combustion chambers.
My guess would be that you are not getting air to your oil injectors and so sucking oil into the combustion chambers.
Old Jul 22, 2006 | 11:24 PM
KJ238's Avatar
Do you have a restrictor on your turbo oil feed line?
No i dont...
Old Jul 23, 2006 | 06:05 AM
two rotors's Avatar
If you get white smoke all the time-----turbo is nfg.
Old Jul 23, 2006 | 10:14 AM
KJ238's Avatar
nope... its when i am idle.. when moving it stops
Old Jul 23, 2006 | 08:10 PM
KJ238's Avatar
lemme try a restrictor first... i'm not sure where to source one though...
Old Jul 24, 2006 | 12:10 AM
KJ238's Avatar
Thanks for the links....
But unfortunately, it's hard for me to procure little items like this... I live in a tiny obscure country... Trying Mazsport now as he will be sending me an interceptor in a bit, so hopefully he can procure one for me....
