Are check engine lights stored even if you clear them?
Old Jul 17, 2006 | 06:15 PM
manek1's Avatar
Question,
If you pull the negative terminal and it clears the CEL does the PCM still store the CEL in it's history?
Basically if I clear the CEL by disconnected the battery terminal and take it to the dealer will they still be able to see that I threw a code if they hook it up to the scanner?
My SRT did that for certain codes.
Thanks all.
Old Jul 17, 2006 | 06:24 PM
mysql101's Avatar
Hmmm, I'm not sure - but I do know if I clear my PCM memory, the car will be able to tell you how long ago it was last cleared. So if the dealer looked, he'd be able to see the car was recently reset.
Old Jul 17, 2006 | 06:54 PM
zoom44's Avatar
yes thats part of the obdii emssions stuff. it reports how long since the dtc was cleared for emissions testing.
once the codes arecleared they are cleared. however depending on the root cause it could re occur or throw a pending again again by the time you get tot the delaer. depends on what test caused the dtc and how often the test is run
Old Jul 17, 2006 | 07:12 PM
Gomez's Avatar
Shifty Bastard.
There are some faults you can't clear. DSC fault codes are stored in the HU/CM. They won't be cleared by disconnecting the battery. The dealer needs to clear them. Those of you who are in the habit of holding the DSC Off switch for seven seconds should be aware of that.....there may be insurance implications in the event of an accident. Unlikely, I know.....
DSC faults won't bring up a CEL, BTW.
Old Jul 17, 2006 | 07:45 PM
zoom44's Avatar
well if you clear any DTC that causes a CEL. its cleared which is mostly the emissions related stuf
Old Jul 17, 2006 | 11:21 PM
You have to drive a certain number of miles before you can get it smog checked.
I think it's 100 miles.
vapor2
Nov 3, 2020 03:38 PM
cschoeps
Aug 6, 2015 12:44 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
