TPMS knows which tire is which?
Old Jul 17, 2006 | 10:27 AM
fullsmoke's Avatar
Anatomy of a corner...
I have an odd question:
Does the TPMS/PCM system know which tire is at which corner of the car? Or, is there anything on the car that logs how wheels were rotated or moved around on the car?
Thanks,
FS
Old Jul 17, 2006 | 10:35 AM
Asmoran's Avatar
Yes, though I'm not sure it's the TMPS that logs it. DSC wouldn't be possible without the car knowing which tires are sliding.
Old Jul 17, 2006 | 10:48 AM
fullsmoke's Avatar
I didn't mean that--sorry, post was probably confusing. Hypothetically speaking, if I rotated my wheels in a random pattern, would the 8 know where each wheel was originally located, and where they are now located?
FS
Old Jul 17, 2006 | 05:19 PM
New Yorker's Avatar
I'm not positive, but I think I read somewhere that the TPMS doesn't know which tire is which. (In fact, I believe this was a criticism of the TPMS system that's been adopted—there was another TPMS technology that I think was tire specific.) If I'm not mistaken, TPMS is triggered if any tire is below (or above) the programmed tire pressure range—but no, it doesn't know which tire is low.
Old Jul 17, 2006 | 05:56 PM
turbosa22c's Avatar
i thought dsc looked at the abs wheel sensors and not the tpms.
Old Jul 17, 2006 | 06:15 PM
fullsmoke's Avatar
Thanks, New Yorker. turbosa22c, we aren't talking about traction control. We are talking about, say, if the 8 can detect/knows if you swap a wheel from the left side to the right.
FS
Old Jul 18, 2006 | 12:08 AM
dsmdriver's Avatar
The TPMS system knows about each sensor individually. If you use Dan Harrison's program, you can see the temp and pressure for each wheel individually.
BUT... It doesn't know or care which wheel is which. The RX8 runs 32 PSI in each tire, so it doesn't matter front/back or left/right. All that turns on is a simple light on the dash that tells you to go check your tires, so no need to know what is what.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
