? about Water Wetter
Old Jul 13, 2006 | 12:18 PM
willsrx's Avatar
How often should I use WATER WETTER products it does not say anything about usage on the bottle or on the website.
Old Jul 13, 2006 | 01:13 PM
Brice-RX8's Avatar
What do you mean by "how often should I use"? You pour half a bottle or so in everytime you change your coolant.
Old Jul 13, 2006 | 01:19 PM
willsrx's Avatar
thanks for the info. brice
Old Jul 13, 2006 | 03:42 PM
Brice-RX8's Avatar
No problem, I was just trying to figure out what you meant. I think you are suppose to change the coolant every 2 years, so I would use half a bottle now, and the other half when you change the coolant. I can't see where Water Wetter would hurt anything.
Old Jul 13, 2006 | 03:50 PM
MazdaManiac's Avatar
Every two years at LEAST. I recommend changing it every year.
WaterWetter is not terribly effective if you are using 50/50.
If you live in a place that has cold weather, you are not going to see a benefit from it because of that.
I live in the desert, so I have only 10% antifreeze. WaterWetter works best in straight water.
It is mainly glycerin (a detergent) and acts as a surfactant.
05rx8mazda
Nov 28, 2015 09:42 AM
arexatemate
Oct 4, 2015 12:36 PM
jDt!
Oct 2, 2015 04:04 PM
DG07
Sep 28, 2015 10:58 AM
