AuxMod and Mini Disc MD Question
Old Jul 9, 2006 | 12:10 PM
dasoviet's Avatar
Is it OK to have both MD and auxmod installed?
I don't care if i loose MD from working.
What i do care is to have to take off the MD because i don't have the OEM facing.
Old Jul 9, 2006 | 01:12 PM
WikkedOne's Avatar
Deals on wheels
You will not be able to have the MD and the AUXmod installed at the same time. They both plug into the same place.
and if you were to install the AUX mod you will have to remove your MD player and replace with the original faceplate
Old Jul 9, 2006 | 04:28 PM
dasoviet's Avatar
Thanks wikkedone!
I appreciate your input
Old Jul 10, 2006 | 09:11 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
In your case, the only way for you to keep the MD player AND have auxiliary input, is to install PIE.
Old Jul 11, 2006 | 03:02 AM
dasoviet's Avatar
Actually i never've used the MD what i don't want to loose is the oem mp3 player. This is a 2nd hand car so i don't have the oriigial trim in place of the MD player.
Anw... i appreciate your input
Old Jul 11, 2006 | 12:32 PM
WikkedOne's Avatar
Deals on wheels
you won't lose the Mp3 player by taking out the MD they are seperate peices.. but without the original face trim peice you will have the MD hole with nothing behind it.. which won't hurt anything but it will look weird
jer2911
Sep 29, 2015 06:37 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
Austin22
Sep 23, 2015 04:46 PM
Wurromurro
Sep 20, 2015 05:02 PM
