replacing NAV with touchscreen questions
Old Jul 2, 2006 | 03:32 PM
twisted8's Avatar
I got a VGA screen that will be using with a carPC replacing my OEM NAV. i got this far but now sure how to discconect this. pull it off, does the white part unplugs or the ribon itself comes off?
also the back of the NAV i see two clips on the side. is that it or how does it come off?
thanks
Old Jul 2, 2006 | 04:02 PM
twisted8's Avatar
ah nevermind, i was able to get it off wihtout removing that ribon
Old Jul 2, 2006 | 04:26 PM
Guino's Avatar
Road Runner Developer
there are a few of those in there, just pull on the corners (the little brownish tips -- not the cable, but the plastic itself).. you should use your fingernails to pull them on both sides one at a time (it moves slightly), then the ribbon cable will be loose and you can just remove it.. when putting back you do the opposite (push the corners after cable in place) see pic:
Old Jul 2, 2006 | 08:25 PM
twisted8's Avatar
thanks! that helped a lot. much easier to work with that unpluged!
mr. GrandGame
Sep 9, 2025 10:41 PM
GracefulShanks
Aug 18, 2015 11:40 AM
MolecularConcept
Aug 5, 2015 04:43 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
