Grand Am Mid-Ohio Update posted to GrandAmAdventure
The update for the Mid-Ohio race has been posted.
http://www.grandamadventure.com/GA_Mid-Ohio.html
Main Link if you want to start at the beginning:
http://www.grandamadventure.com/GA_main.html
I hope you enjoy it!
Mark
Mark
Good write-up Mark.....did the fuel problem go away completely with the fuel pump swap? That's the exact thing mine was doing
I put the new pump in the L side...and the other in the R side for good measure
I have to wait till th 28th to see if it works.
I know you don't have the fuel pump modification for an option.....Damn rules!
I have to wait till th 28th to see if it works.I know you don't have the fuel pump modification for an option.....Damn rules!
Great...now I'm not going to know if just the new pump solved the problem...
I guess if I leave the aux pump shut off and it doesn't do it...then It was the pump.....if not it needs the additional pump
Originally Posted by markodell
Yes, the new fuel pump solved it completely. Good Luck with yours!
Mark
Mark
Originally Posted by alnielsen
Is this a differenct OEM pump or a aftermarket pump? As far as your overheating problem, are your hoses collapsing. That would explain why, under higher rpms, that the water temp rose.
That's a good thought, but Jon checked the hoses carefully and they were weren't collapsing. They were all practically brand new hoses.
We think at this point the motor will need to be dissasembled to determine the root cause. Actually we appeared to be down on power from the start, so it rebuild time...
Mark
Great writeup, I was wondering why I didnt see the 128 car in the result section on the Grand Am website.
As for the down on power(assume ur comparing to the speedsource rx-8s), would it be because of the greddy engine management not extracting all the power outta the renesis? last I checked on this forum, the greddy system isnt the best. Any considerations to move to a more advanced engine management system?
________
AshleyY
________
AshleyY
I don't think it is the engine managment, because it was plenty fast at VIR and Daytona. At Daytona we were able to draft and pass other cars - BMW's, Cobalts, some Acuras, and even a few of the Speedsource prepared RX-8's. The same was true at VIR. At Mid-Ohio, we couldn't draft and pass ANYBODY. Not one fricken' car.
I suspect when we tear the engine down, we'll discover the problem.
Mark
I bet it was because you used synthetic oil.
(Heh, just kidding.)
I saw that graphic job at VIR. It was one of the most amazing bits of graphic work I've ever seen.
BTW, where'd you get a 3rd oil cooler? A couple of us (in stock trim) have wondered if heat might be causing some of the misfire CEL's we've been getting.
(Heh, just kidding.)I saw that graphic job at VIR. It was one of the most amazing bits of graphic work I've ever seen.
I'm afraid I couldn't tell you where the third oil cooler came from. It doesn't look like something specifically made for the RX-8, just a generic aftermarket part that Doc plumbed in. You can get that kind of thing at Pegasus Racing, etc.
No not yet.
A couple of days ago I emailed the data logger information to Doc, and he pointed out that we were indeed running lean above 8000 rpm. Too bad he wasn't with us at the track.
I don't know if that changes things or not. I think Doc is coming up to take a look at it and they will decide what to do next week.
Mark
Mark
I love reading this. Thanks a lot Mark. The GA RX-8 Club will be at the Barber Motorsports Park Grand Am race. I'll be sure to stop by. You have a large following of devoted readers! Good Luck!
Mark,
Thanks for the stories, makes for great reading. I had forgetten how much elevation change there is in the upper paddock at Mid-Ohio. I was at a track event there yesterday and ended up parked up there. I can see why you had problems!
It was my first track event and I had a blast. I have a lot to learn, but studying your videos and countless simulation laps on rFactor gave me a good start. At least I knew the course layout and proper line.
Looking forward to the next update.
Mark
Guys,
I have posted an update to the GrandAmAdventure website regarding the Barber race weekend:
http://www.grandamadventure.com/GA_Barber.html
Its a little different in some regards from my previous work - that is all I can say....
Enjoy,
Mark
Enjoy,
Mark
NOOOOOOOOO!!!! This is one of the few things I patiently wait for to read and now it's ruined! I seriously loved your 'diary' you would post after every race with all the gritty details that only car junkies could appreciate. Thanks a lot for all the fun stories Mark.
I seriously hope that you do find someone else to race for. Good luck Mark and thanks a bunch.
^^^ Me too. I really enjoyed reading the diary. It was as close to being an actual driver you could be without suiting up. It had a very engaging writing style.
Thanks for your efforts and we hope to see more in the future.
