Last question about Racing Beat intake
Old Jun 28, 2006 | 08:01 PM
Rx-8 TT's Avatar
I just installed my Racing Beat intake and duct.
After I finish the installation, 2 part were left.
One was like black long plastic panel and another one was like...long pipe?
In order to install the duct, the instruction said I had to remove the
those 2 things.
1) Do I just leave the 2 parts alone? or how do I put its back on?
Another quesiton is that while I put the long pipe(?) out, I had to remove the
little vaccume hose.
2) Do I just leave it alone too somewhere behind intake box? and is it going to
okay? not cause any problem to my car?
Old Jun 28, 2006 | 08:11 PM
NgoRX8's Avatar
umm, the pipe that was in front of the intake you will leave off. what is the black long plastic panel? gotta pic?
Old Jun 28, 2006 | 08:25 PM
Rx-8 TT's Avatar
FSecond picture is long pipe I ma taking about
and thrid one is the long plastic panel. I do not really know what I have to call it.
And in the first picture. there is little vaccume thing, round and gold metal,
I took out little hose from there, and just leave off too?
Attached Thumbnails Last question about Racing Beat intake-dscn2637.jpg   Last question about Racing Beat intake-dscn2638.jpg   Last question about Racing Beat intake-dscn2639.jpg
Old Jun 28, 2006 | 08:36 PM
NgoRX8's Avatar
yea ok, that long pipe vaccum is the vfad. you leave that off. you can use the ram air duct in its place if you wish. the lil hose you will take out too and you should have a red cap that came w/ the revi to cap off the hose hole near the engine.
hmm... where'd you take off that panel from? which part on the car?
Old Jun 28, 2006 | 08:52 PM
Rx-8 TT's Avatar
That panel was upon the front bumper. upon the white stroform.
and what is the red cap? Is it right one on the picture?
This is only one red cap I can see in the Racing Beat Box.
And what should I do with the red cap? Can you tell me detail things?
Old Jun 28, 2006 | 09:01 PM
NgoRX8's Avatar
that's the red cap. you remember where the end of the hose is? the other end, closer to the engine. that cap is suppose to replace the hose. you're just closing it off.
Old Jun 28, 2006 | 09:15 PM
all of that stuff stays off... the red cap is very important. if you cant find out where to put it from the instructions. let me know and i will photo for you...
Old Jun 28, 2006 | 09:25 PM
Rx-8 TT's Avatar
There was no instruction on my RB Intake Box.
So...I don't have to put back the two things on the picture. Just leave it off.
And the red cap should go..somewhre on the hose.
Could you show me the picture where the red cap is suppose
to go?
Thanks.
Old Jun 28, 2006 | 09:53 PM
jdzoom8's Avatar
The red cap goes on the right hand side of the intake runner. You need to cap the line where the vacuum hose attached from the OEM intake. Look at where your racing beat intake attaches to the intake runner. Then run your hand on the underside of the intake runner (at about 4 or 5 o' clock) towards your windshield, you will find about a 1-2 inch long, 1/8" diameter line that sticks out. This line needs to be capped. Your rx-8 will not run properly without this capped.
Old Jun 28, 2006 | 10:03 PM
willhave8's Avatar
Picture or where the red cap goes ==> https://www.rx8club.com/showthread.p...light=REVi+CEL . If you run the car without the cap, you will get a CEL.
Isn't the part in your second and third picture the piece that goes back on top of the fascia inside the engine bay?
Old Jun 28, 2006 | 10:06 PM
Rx-8 TT's Avatar
I found the it, can you guys check it out? am I right? (first picture)
And...I am wondering if I remove the hose from there, whole things ( little
black roung thing and wire connertor with green one ( second picture))
will be taken out. Right?
But do I still have to connect the green wire on there??
Attached Thumbnails Last question about Racing Beat intake-dscn2656.jpg   Last question about Racing Beat intake-dscn2648.jpg
Old Jun 28, 2006 | 10:33 PM
Rx-8 TT's Avatar
I cannot put it back cuz of duct.. Is there anyone who put it back with duct?
Old Jun 28, 2006 | 10:36 PM
cool.
enjoy.
Old Jun 28, 2006 | 11:08 PM
Rx-8 TT's Avatar
Anyone has nice picture you took while you were working with duct?
https://www.rx8club.com/showthread.p...=remove+bumper
This is the best picture I can see, but I want to see the other angle picture
Up, side, bottom....especially upper side.
And please tell me what I have to do with the hose after I put the red cap on.
(Pintures)
Old Jun 28, 2006 | 11:16 PM
take it all out... it is what controled the vdaf...
put it with the rest of the stuff you took out..
Old Jun 29, 2006 | 02:01 AM
Hmm I have a question tho.
I have K&N 2nd Gen. and RB Air duct.
I just leave the part in its place, cuz K&N didnt say anything about it. and Ram Duct didnt say anything either.
Should I just get something and "close" that hole as well?? Its still connected now. Thanks.
Old Jun 29, 2006 | 02:06 AM
if you are talking about the hole where the red plug goes...
yes you do..
Old Jun 29, 2006 | 02:50 AM
NgoRX8's Avatar
make sure its stuck tight too because there have been some occurrences of them falling off.
Old Jun 29, 2006 | 05:46 AM
jdzoom8's Avatar
I actually damaged the little cap that was given to me with the MS CAI, but that might have ended up being for the better. I went to the Auto Store and got a much more robust cap to avoid having the problems of it falling off. You can always put some silicone on the cap to keep it from falling off.
Old Jun 29, 2006 | 03:30 PM
Rx-8 TT's Avatar
Ok. Guys. Finally I got it. work find and no Engine light.
Finall Question.
1) Do I still connect this green wire on it even though the hose is removed
from the green connector? (First Picture)
2) Just remove those hoses from intake and leave off, no using
Am I right? (Second pic)
Attached Thumbnails Last question about Racing Beat intake-dscn2659.jpg   Last question about Racing Beat intake-dscn2658.jpg
Old Jun 30, 2006 | 09:51 AM
1. you dont need to.. i just zip tied it out of the why..
2. yes
Old Jul 1, 2006 | 01:24 AM
Rx-8 TT's Avatar
If I do not connect the wire that green color (VFAD???),
the engine light comes up. Is it normal? or
The engine light should not come up even though I do not connect it?
Old Jul 1, 2006 | 07:17 AM
Mazda-Rati's Avatar
the WANKEL made me do it
The green connector doesn't need to be attached to anything just zip tie it and put it out of the way. You should not get a check engine light with it unattached.
Old Jul 1, 2006 | 08:47 AM
Rx-8 TT's Avatar
oops...I should double check it.
8is>enuff
Sep 24, 2015 08:57 AM
SupraG
Sep 21, 2015 12:09 AM
8is>enuff
NE For Sale/Wanted
Sep 3, 2015 07:57 PM
PTQLam
Aug 16, 2015 05:40 PM
