spark plugs
Old Jun 28, 2006 | 07:56 AM
sportsgirl's Avatar
spark plugs
can anyone advice me on the following spark plugs?
and where can i get them?
1. denso
2. autoexe
3. NGK
thank you
Old Jun 28, 2006 | 08:07 AM
mkl22's Avatar
just called the spare parts dealer. S$180 for a set of the new version of stock plugs. NGK
its NGK RE7CL and NGK RE9BT. 2 each. supposed to be iridium plugs. Else you can try RX7 plugs which some say are fine as well. The only difference i could see is that thr RX7 plugs BUR-7EQP has a shorter reach of 19mm vs 21mm for the RE7CL. both the RE9BT and BUR-9EQP have the same dimensions. RX7 plugs are USD$7.60 each and available from www.sparkplugs.com. They are normal platinum plugs
Old Jun 28, 2006 | 10:26 PM
coupe07's Avatar
SC 300HP!!
1. denso
2. autoexe
3. NGK
thank you
Autoexe does not have spark plugs.
Most japs recommend only NGK. Denso is, sadly, not recommended.
Old Jun 29, 2006 | 12:30 AM
lennon's Avatar
Coupe07,
Do you think is there any harm to use rx7 NGK sparks??
tq
Old Jun 29, 2006 | 01:01 AM
Imidazole's Avatar
"$180 for a set of the new version of stock plugs"
Hold on a second, I thought spark plugs were $3-$10 each. Four spark plugs = $12-$40 for a set.
How did you end up paying $180?
Old Jun 29, 2006 | 01:07 AM
Mr Bing's Avatar
huh??...wat kind of spark plug is that??.....i dont think thats for our 8....
in m'sia...it cost around rm350-380.....around USD100......ngk...same like original...
....and we only should change it once it reach 50k km....
Old Jun 29, 2006 | 01:12 AM
INXS's Avatar
INXS
We need COLD racing s/plugs...
Old Jun 29, 2006 | 01:14 AM
lennon's Avatar
You're not encourage to do that....... This a high rev performance car, not normal sedan....... You should change it more often.....
Old Jun 29, 2006 | 01:15 AM
Mr Bing's Avatar
o...ye ke....i shud remember that....
coz last time N1 did advice me to change it every 20k......
but C&C ask me to change it between 40k-50k km....
Old Jun 29, 2006 | 01:17 AM
lennon's Avatar
No No NO...... Cold plugs (rating 10 or 11) are not suitable....... You'll have trouble in idling and starting up engine......
Old Jun 29, 2006 | 01:21 AM
coupe07's Avatar
SC 300HP!!
try getting that for $12 or $40 per set. I will buy 100 sets from u!!! Is it so cheap in the states?
Rotary spark plugs are expensive and are recomended to change ard 30,000 to 35,000km. We do not have to change every servicing. Using back the original NGK plugs is the best.
Old Jun 29, 2006 | 05:52 AM
sportsgirl's Avatar
do u have e contact or address of any recommended spare parts dealer
thanks
pls dun quote me macwell ya
Old Jun 29, 2006 | 06:21 AM
c h o x's Avatar
Stock...
Most japs recommend only NGK. Denso is, sadly, not recommended.[/QUOTE]
Why is densol not recommended??
and what if it's used? i juz changed mine to densol iridium...please tell me they're at least acceptable....i spend $260 on 4 of those!
Old Jun 29, 2006 | 06:46 AM
CoupeM's Avatar
Night Rider
ngk 7 and 9 rating is equvalent to ik wat hur?
Old Jun 29, 2006 | 07:41 AM
Emperor's Avatar
aka Spectre
The cheap plugs are normal ones. The ones we use are iridium ones.
How come denso not recommended? I always like denso and planning to use it next somemore.
Old Jun 29, 2006 | 07:50 AM
mkl22's Avatar
there are no cheap plugs for rx8. only iridium type.
Old Jun 29, 2006 | 09:52 AM
virus's Avatar
Hi All,
I wouldn't say its bad to use DEnso...i think its quite subjective...
I used to use denso and now i am using NGK....so far not much of a diff. ...of cos price play a big part...comparing $180 to $240....overall the function of the spark plug is basically to combust the A/F , hence i guess you can base on which spark plugs give you the highest firing power, which one will be more durable, price etc.....
Old Jun 29, 2006 | 10:02 AM
madmax_rx8's Avatar
Originally Posted by virus
Hi All,
wow bro, you pay only $240 for Denso Iridium huh?? that is really a gd price man i thought i have already got a good deal at $255.
BTW is there a diff between Denso Iridium(yellow packaging) and the Denso Racing Iridium (Bluish Packaging)??
Anyway IMHO, i have just change to Denso Racing Iridium, so far the only difference is abit smoother only lor but the price to pay is $255
Old Jun 29, 2006 | 10:13 AM
virus's Avatar
i am not sure wats the diff btw the packaging ......
but if you want to improve your performance ...try using Spark amplifier like Ignite rev or HKS twin power.....on the other hand you can re tune your ignition timing or get a good spark plug wire (ie: 2 that i highly recommend , RE sprk plug cable and R magic. If you have the budget try Fujita ones ...not bad too)
Old Jun 29, 2006 | 09:33 PM
sportsgirl's Avatar
Hi All,
virus, where i can get e NGK plugs for 180?
Old Jun 29, 2006 | 11:07 PM
takahashi's Avatar
I have the Fujita Engineering (rebadged NGK racing) spark plugs.
I have their spark plug cord too.
I have my review on those plug when the car is having hesitation on high revs (~9000rpm). It is solved and I found the plugs need to be cleaned if not changed.
details here https://www.rx8club.com/australia-new-zealand-forum-37/hesitation-high-rev-found-solution-87376/
Old Jun 29, 2006 | 11:28 PM
mkl22's Avatar
hey sportsgirl, sorry for not replying. you can call fong yat at 62935722. blk 685 race course road.
Old Jun 5, 2007 | 06:19 AM
200HEY's Avatar
sparksplugs.com guy told me the rx8 needs 2 RE8C-L and 2 RE9B-T spark plugs is this correct? can the RE8C-L be used instead of the RE7C-L.
Also do these help combat the cold start, moving the car two metres , turning the engine off and then be the victim of flooding that so many RX8 owners have experienced including myself last week!
Old Oct 9, 2011 | 11:27 PM
se3p_s's Avatar
I am Using hks plug is it good or bad..
Old Oct 10, 2011 | 12:48 AM
TX
Nice bump, Thanks for searching though.
It depends which HKS plugs you are running. Are you turbocharged?
