Broken Rear Swaybar Endlink
Old Jun 25, 2006 | 11:58 AM
92tsiawd's Avatar
Anyone every break their rear swaybar endlink? I have RB sway bars in the back and a greddy rear strut tower bar. Broke the rear endlink once after the tower bar was installed. Installed a new endlink yesterday and it broke again. I am wondering if a rear strut tower bar could break endlinks when combined with sway bars?? Any insight is good, thanks
Old Jun 25, 2006 | 12:08 PM
Are the struts both OK?...if you have a broken strut/spring it will load up the sway a lot more than normal
Old Jun 25, 2006 | 02:11 PM
92tsiawd's Avatar
Yea, the struts are both ok, I have S-tech springs on there, the rear suspension seems completely fine
Old Jun 25, 2006 | 02:24 PM
How much preload ( tension) is on the end-link with the car sitting on a level pad?? If there is too much then they can fail early as well as give you some weird handling quirks.
Old Jun 25, 2006 | 02:29 PM
Spin9k's Avatar
Momentum Keeps Me Going
You could have the swaybar mounted upside down - it's relatively easy mistake to do if you did not match the new bar position and it's shape to the old - and it will mount up both ways. Search for some pics of the way it's supposed to be - or check the service manual. Breaking endlinks is not normal nor easy to do - if all other parts are installed correctly.
Old Jun 25, 2006 | 04:22 PM
Mikelikes2drive's Avatar
i agree with spin9k... if u mount the sways upside down... itll break the endlinks really quickly
happened to me.
Old Jun 25, 2006 | 05:10 PM
92tsiawd's Avatar
Frig, I think it is upside down after doing a little searching. The word racingbeat part number on the swaybar is suppose to be upside down. Thanks guys for the heads up
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Brokegang
Jan 3, 2016 12:45 PM
yankeepicker
Sep 11, 2015 05:42 PM
