HELP with rear bumper mod
Old Jun 22, 2006 | 08:44 PM
jammiman's Avatar
I want to take the two corners bumpers off of the back of my 8. There are two little plastic "pin bolts" that are holding these pieces on from the bottom. Usually, you pull the center piece out a little, and the whole thing just pops off, but these won't budge. Is there a trick to them? Should I just cut them off, and replace them with other plastic bolts? Whats the deal?
Old Jun 23, 2006 | 11:48 PM
davidwanj's Avatar
there is actually 4 plastic bolts...they are actually called pressureless bolt, all you need is a flat head screwdriver to take them out...but not sure what you mean by two corner bumper...behind the mat there is also 2 nut screw on each tail light and a slap on plastic to keep tail light from moving, next to the tail light there is 2 more screws deeper inside, below the car there is 3 big pressureless screws, at the rear wheel there should be like 4 or 5 pressureless screws, if you are planning to remove the rear bumper you'll need to take out all those screws listed above
Old Jun 23, 2006 | 11:55 PM
tiggerlee's Avatar
May Cause Anal Leakage
Not sure if this will your situation. Personally I've never removed the rear bumper. https://www.rx8club.com/showthread.p...ghlight=bumper
Old Jun 24, 2006 | 12:51 AM
NgoRX8's Avatar
flat screwdriver is your best bet. and a lott of etching it lil by lil.
gwailo
May 14, 2024 06:57 AM
rxwilly8
Sep 2, 2015 02:42 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
Jazzmeson
Aug 30, 2015 02:42 AM
Jazzmeson
Aug 30, 2015 02:40 AM
