View Full Version : Loss of Braking in Spin?
Sparky
06-19-2006, 05:04 PM
About a year ago I had a particularly nasty spin and as I was traveling backwards the brake pedal went to the floor leaving me without brakes until I stopped. When I released the pedal and reapplied everything was back to normal. I had forgotten about it until this past weekend when Jim Reyenga had the same thing happen in a borrowed RX-8 (not mine). So apparently I wasn't imagining it and/or my car isn't defective. Any ideas/explanations on what's going on here?
alnielsen
06-19-2006, 05:15 PM
Was DSC turned on? Could it be the DSC was fighting for control and not letting you have any?
Sparky
06-19-2006, 05:26 PM
DSC was completely off in both cases (i.e 11 second hold). We never autox with it on intentionally.
alnielsen
06-19-2006, 05:33 PM
Believe me, I understand why. Could the force of the spin have moved all the brake fluid out of the base of the master cylinder? Leaving it against the side of the reservor? If this is posible, the piston in the master cylinder would be pushing air.
ULLLOSE
06-19-2006, 05:34 PM
I would guess the ecu/pcm did it as some sort of ice mode program.
Sparky
06-19-2006, 05:46 PM
All those can do is interupt brake pressure from the pedal to the wheel cylinder. This is allowing the release of brake pressure somehow. Doesn't feel anything like ABS, more like loss of vaccum boost in a car with poor brakes. I've spun several other times and these two occurances are the only ones I know of where this happened. Both were pretty violent but ended up with the car sliding backwards.
dannobre
06-19-2006, 07:33 PM
Did the engine stall???
ULLLOSE
06-19-2006, 08:02 PM
Then stop doing that. :bootyshak
ChopsMcgraw
06-19-2006, 08:55 PM
Wrong pedal??
Sparky
06-19-2006, 09:03 PM
Nope. Both feet in. :)
MazdaManiac
06-19-2006, 09:08 PM
Wow. That is scary.
I'm gonna go try to duplicate that tonight.
Sparky
06-19-2006, 09:49 PM
I keep telling myself that. :banghead:
Razz1
06-19-2006, 11:41 PM
Ja, ULLLOSE says I have skinny wheels, why don't you get some like me?
Then you can really :bootyshak your 8 and have fun!
TeamRX8
06-20-2006, 02:07 AM
that's typical for most ABS systems when the wheel direction reverses while going backwards
hogcar
06-20-2006, 07:38 AM
Try both feet OUT!
edj
06-20-2006, 08:27 AM
i've spun several times while autocrossing and the brakes on my 8 do stop working
briefly while moving backwards. normally this is not a problem except for the one time
i got the car stopped about 20 feet from a light pole...
fyi, an ice driving tip. if you are headed toward a tree and your tires can't get any grip
on the ice to turn and the ABS won't let you lock up the brakes, turn your engine off
and pray you stop before you hit the tree!
TeamRX8
06-20-2006, 09:19 AM
yeah, but did you shake it all about ... :cwm27:
zaglo6204
06-21-2006, 03:11 PM
goodness gracious, that was painful
Hyperborea
06-21-2006, 03:40 PM
What is this all about?
TeamRX8
06-21-2006, 08:58 PM
you've never done the Hokey Pokey?
Hyperborea
06-22-2006, 05:45 PM
You put your right foot in,
You put your right foot out;
And you shake it all about.
You do the Hokey-Pokey,
And you turn yourself around.
That's what it's all about!
I was making another "Hokey Pokey" reference. :mdrmed:
Blue87Sport
06-23-2006, 12:33 AM
Wasn't that the cause of the problem in the first place?!? :crazy:
OMG, it's a recursion problem :lol:
