How do I mount used tires?
Old Jun 15, 2006 | 03:50 PM
msrecant's Avatar
Hubble has been saved!
I just got 4 used Potenzas (about 2K miles) to replace the worn out Potenzas (20K) on my 8.
Based on the tire having a single direction of rotation, when I line them all up in the same direction two tires have the right edge slightly more worn and two tires have the left edge slightly more worn. This is as expected.
My question is, when I have the tires put on the car, should I have the worn edge facing IN or facing OUT? Or does it simply not matter?
Old Jun 15, 2006 | 04:16 PM
Skythe's Avatar
Lascivious Post Whore
OH I see, for example if you put the mount left one on the right side of the car then the worn corner will be on the inside and vice versa for the other. I think at this point a good alignment is the only thing that counts, but depending on driving habits then perhaps putting the worn part on the inside will help encourage you to wear the otherside instead of wearing out the worn side even more. The tech should be able to do it in such a way that would influence wear in a more balanced way.
Old Jun 15, 2006 | 04:17 PM
ZoomZoomH's Avatar
Mulligan User
i say facing IN, as cornering usually involves more outer edge wear.
Old Jun 15, 2006 | 04:23 PM
msrecant's Avatar
I checked with the previous owner and, yes, the worn edge used to be the outside edge.
vapor2
Jul 9, 2016 07:35 AM
05rx8mazda
Nov 28, 2015 09:42 AM
OnebaddRx8
Oct 17, 2015 10:05 PM
rx8convert22
Oct 1, 2015 07:09 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
