problems with 275 rear
Old Jun 14, 2006 | 09:15 PM
yellowRX's Avatar
Piston? What's a piston
Dose anyone have a problem with rubbing 275 in the rear? the offset for my rims are +30 . Should I just use 265? it only happens when I go over a bump on the road.
Old Jun 14, 2006 | 09:19 PM
NgoRX8's Avatar
you're rubbing your fender lip. just get it shaved.
Old Jun 14, 2006 | 09:29 PM
That offset is pretty low....makes the wheels stick out a lot more than stock.
What width are they.....I have 9.5" with 45 offset...and they just clear with 2 deg neg camber and 275's in the back.......
Old Jun 14, 2006 | 09:36 PM
Kel Rx8's Avatar
if your not 1st your last
what Ngorx8 said
I use to rub before shaving the rear a quater of a inch down.dont go pass tack weld.
Old Jun 14, 2006 | 09:38 PM
\\Konig\\'s Avatar
turrrbo!
i have 9.5's in the back with 275's. No rubbing issues yet. you just need to have the right offset.
Old Jun 14, 2006 | 09:39 PM
yellowRX's Avatar
thanks guys, it looks like im gonna have to shave them. Better then getting diffrent tires. the rims are 18X9.5 other then that i'm really happy.
Old Jun 14, 2006 | 09:40 PM
yellowRX's Avatar
Yup, it's the +30.
Old Jun 14, 2006 | 09:43 PM
NgoRX8's Avatar
yea, 9.5 +30, all you need is the shave the fender a bit and no more rubbing. FE3P and XDEEDUBBX had their's shaved and I will be doing that soon as well. it allows for a nice aggressive look.
Old Jun 14, 2006 | 09:47 PM
yellowRX's Avatar
Where did you guys get it done?
Old Jun 14, 2006 | 10:09 PM
NgoRX8's Avatar
they got it done at status
1402 PCH BLVD
HERMOSA BEACH,CA 90254
310-937-8382
Old Jun 15, 2006 | 12:11 AM
Mikelikes2drive's Avatar
ef1 motorsports in signal hill does a very good job
Old Jun 15, 2006 | 12:23 AM
NgoRX8's Avatar
yah i heard about ef1. they do fender rolling. people have mixed reviews about cutting and rolling, doesn't really matter.
Old Jun 16, 2006 | 12:02 AM
ElusiveFX's Avatar
8B8B8B
EF1 is a crazy sick shop, tons of hot rides go in and out of there. They should be able to take care of you.
Old Jun 16, 2006 | 12:12 AM
i would reccomend status. Fender cutting is much better, I've seen a few people with rolled fenders that had their paint cracked , and there is a higher tendency to warp/ bend the fender if rolled.
Old Jun 16, 2006 | 09:05 AM
sssuperman82's Avatar
i've had Returned
i have 275 on my stock tires ....i have no problems what so ever, it filled the gap in my tires, but i think is too much for stock tires so im getting 245's now that im due to change....
Old Jun 16, 2006 | 09:35 AM
Spin9k's Avatar
Momentum Keeps Me Going
I would recommend rolling. Cutting exposes the bare metal to eventual rusting, it can never be painted as it was w/multiple coats, and weakens the joint area. But poor rolling will definitely crack the paint and cause similar longterm problems, so use the right tools, do it slowly and heat the area first and there is no paint cracking.
275s rule!
Old Jun 16, 2006 | 11:14 AM
275s rule!
thats only if you don't sand it down a lil and primer it, and throw on a few coats of paint. If you get it rolled make sure that you go to someone that knows what he's doing. I've gotten my fenders rolied before on one of my previous cars by a reputable body shop and the paint still cracked, and over time, it eventually started to crack parts of the paint by the exterior fender. i wouldn't worry too much about "weakening the fender" either, i've seen 100's of cars with cut fenders with no problems.
Old Jun 16, 2006 | 10:15 PM
Spin9k's Avatar
Cut (what would joe owner use and how much skill to make a nice even cut?), sand & clean, mask, prime, then few coats of paint..... come on... this isn't an easy, quick and certainly not a do-it-yourself method...sounds like sumin a body shop would need to do and costa bunch plus the paint matching/layering process to match our flake/clear coat isn't just simply spray and you're done. PITA if you ask me and $$$.
Rolling on the other hand is realatively easy, even for an rookie who can read directions and has only some mechanical skills. No body shop required if you take your time and are careful. It also takes only a few minutes to a half hour per fender. All you need is a quality rolling tool and a heat gun....and when you're done with that work, and that alone, you're done period. Simple, quick, painless, cheap too esp if you've a friend with the tools needed.
And I know, I just did mine that way, myself, alone and it was quite easy and worked very well.
Old Jun 17, 2006 | 12:34 AM
Or you could buy wheels with the correct offset..that fit
Old Jun 17, 2006 | 02:49 AM
MrWigggles's Avatar
Yeah, I have 275 tires with 9.5" rims that have a +42mm offset and I have no rubbing. Also my tires go all the way out perfectly to the edge of the fender and don't hang out a half inch.
Doing +30 with 275 on a 9.5" and you tires will hang out a little unless you get your car lowered slightly. Getting the rear end lowered a couple inches will likely pull the top of the tires inwards almost a half of an inch. (Of coarse with the +30's you will have to have your fender's modified by tucking or cutting as others have described.)
-Mr. Wigggles
Old Jun 17, 2006 | 02:56 AM
yellowRX's Avatar
I guess I have no choice. I didn't want to do this just because with rolling can cause cracks in the future, and cutting might get rusted. I guess i'm gonna have to see if I can meet up with XDeedub and see how his looks, so what do you say XDee, are you gonna be at any local meets anytime?
Old Jun 17, 2006 | 07:04 PM
NgoRX8's Avatar
i just got my rims on and im rubbing too. time to get fender shaved.
xAgyex
Jun 3, 2026 03:47 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
WingleBeast
22
May 23, 2016 09:22 PM
Belalnabi
Jul 17, 2015 07:48 PM
