Tire pressure monitoring system
Old Jun 8, 2006 | 12:56 PM
John426's Avatar
I just got new rims put on and I forgot to tell them about the tire pressure monitoring system and now the light is flashing. Does anybody know what I have to do now to get rid of it?
Old Jun 8, 2006 | 01:03 PM
expo1's Avatar
He's as bad as Can
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-cover-tpms-light-47499/
Sorry, there is no other PROVEN way
Old Jun 8, 2006 | 01:09 PM
John426's Avatar
Can i take the sensors off the old tires?
Old Jun 8, 2006 | 01:28 PM
Go48's Avatar
You can take the sensors off the OEM wheels, but unless the new rims are set up for TPMS and they will accept the OEM sensors, you're out of luck. In addition, if you had the tires installed at a non-dealer facility, they may very well have destroyed the sensors in the process of removing the tires from the OEM rims. BTW, the OEM sensors go for about $100 USD each.
To get rid of the warning light, try a piece of black electricians tape over that point on the dash console. A ghetto fix for sure, but it works.
Old Jun 8, 2006 | 01:29 PM
Nemesis8's Avatar
Bigus Rotus
Black electrical tape LOL
Old Jun 8, 2006 | 01:44 PM
FABRO's Avatar
Registered Ricer
you'll forget about the light after a few months, and won't even notice it going off anymore.
Old Jun 8, 2006 | 02:25 PM
John426's Avatar
Thanks for all the info
Old Jun 8, 2006 | 05:08 PM
Go48's Avatar
Sure, glad to help.
Since you are apparently new to the forum, I suggest you do some searching and reading before posting a question. Just about everything you can think of has been discussed at length in the years since the RX-8 hit the market. For example, there are several threads dealing with the very question you asked and a few that deal with, at length, different attempts to disable the TPMS warning ligjht.
Old Jun 8, 2006 | 05:36 PM
John426's Avatar
I'm not new to the forum but I also don't sit in front of the computer all day and read every tid bit of info about RX8's and there problems. I sincerely apologize to the RX8 club for not catching the solution to the problem I'm having with one's in the past!
Old Jun 8, 2006 | 05:43 PM
expo1's Avatar
He's as bad as Can
No need to apologize, honestly this doesn’t come up that often and in general the replies to you have been civil. Now you want to see flames look up any mileage thread started after 2005. Do to the age of this forum searching can be frustrating at time. Instead of using the basic search try searching in the sub-forums that best match your issue or use advance and only search 6-12 months worth of threads instead of 3 years worth.
fireishot34
Sep 5, 2015 06:45 PM
Octomus
Sep 3, 2015 11:40 AM
20b-3rotor
Sep 2, 2015 08:54 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
