Volks rubbing/ Suspension ?'s
Old Jun 8, 2006 | 12:32 PM
VarneyMazda's Avatar
Northeast Pimpin'
I finally got my car back with the gt-7's installed heres the problem
The driver side rear rubs SLIGHTLY on the rear fender lip when the car is being cornered hard. (rubs even more w/ people in the car)
Im thinking a harder suspension would fix this
now ive been told if i get a new suspension set-up that i can adjust my camber to change this.
now what type of suspension should i be looking at..
Ive been told TIEN by multiple people, but have been looking for some other opinons
Money isnt really the issue but more of getting my car right so that it doesnt rub and handles better.
Old Jun 8, 2006 | 12:40 PM
dtorre's Avatar
Ultimate ****** Goderator
Have Koni shocks with Tein S techs....greatest investment into the car til date ((waiting to see if it holds when I get my Axial Flow Short shifter ))
Old Jun 8, 2006 | 12:53 PM
Northeast Pimpin'
more looking for the adjustable type of suspension.
Im thinking if i lost some weight i probably wouldnt have this problem..
Old Jun 8, 2006 | 01:49 PM
DaveRX8's Avatar
I have Tein with Volks also and I still rub. 18x9.5 +40 in the back. It barely hits though so when I get my camber adjusted it should be ok. My camber is only at like -0.9 in the rear and ill try to get it to -1.8 or so.
Old Jun 8, 2006 | 01:53 PM
Northeast Pimpin'
do you have to have tiens or a coilover to adjust your suspension
or can i have my mazda shop adjust it a little bit
Old Jun 8, 2006 | 04:18 PM
DaveRX8's Avatar
The coilovers, are adjustable. Then just take it to get aligned and print out your own specs that you want. Search around on here to find alignment specs. Under the racing section there is a sticky that is alignment specs for street and track use.
Old Jun 8, 2006 | 07:31 PM
RA-Eight's Avatar
Scuderia
How's the treadwear? I can't imagine it wearing even?
Old Jun 8, 2006 | 10:22 PM
Sounds like you have the wrong off set.
You need coil overs to raise the height. They are stiffer to!
Old Jun 9, 2006 | 08:42 AM
Northeast Pimpin'
the offset is fine.. the rubbing is minimal. it only rubs while being cornered hard with the throttle wide open
Old Jun 9, 2006 | 10:30 AM
I have 19 inch te37's with a +34 offset in the rear running 275/30's. Im also slammed on HKS Hipermax II'S. I had some rubbing issues as well but I got my inner fender's cut and that resolved all my problems.
Old Jun 9, 2006 | 10:33 AM
NgoRX8's Avatar
yea if its a problem for you, i say get your fender cut.
Old Jun 9, 2006 | 10:42 AM
Rowena Rx8's Avatar
Your Rotary Mistress
Im also thinking about volks as well...I might have to do this when I get my wheels!
yurcivicsux
192
Sep 12, 2017 10:54 PM
duworm
Oct 1, 2015 04:57 PM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
