Original ECU remap by RE AMEMIYA
Old Jun 7, 2006 | 12:25 AM
coupe07's Avatar
SC 300HP!!
Due to popular demand, RE AMEMIYA has decided to do a remap on original ECUS for fans here. However due to time constraint, they could only do a limited number. I already have 8 cars on hand for this. PI cars need this reflash more than the MM cars. This is a good opportunity as there is only minimum downtime for ur car. Only takes a while to do that.
1. Speed cut removed
2. Rev cut increased.
3. Fuel efficiency increase. (Varies from person to person)
4. Temperature reduced.
Please DO NOT PM me. They will not be replied.
Direct ur questions here, or call office at 67474360 for further enquiries.
Old Jun 7, 2006 | 12:30 AM
INXS's Avatar
INXS
C7,
Costs? When is the next available slot? Mines a PI(A)
tems900's Avatar
Ant re-mapping of Fuel & Ignition ?
Old Jun 7, 2006 | 12:42 AM
Gomez's Avatar
Shifty Bastard.
Just out of interest, what level are your cars RPM limited at?
What is the new temperature set at?
Old Jun 7, 2006 | 12:47 AM
Fab 8's Avatar
I am interested in the remapping. Does it cater for any mods like the RE intake? Thanks.
Old Jun 7, 2006 | 12:56 AM
coupe07's Avatar
SC 300HP!!
only ECU remaps. No additional tuning for other parts. Interested, call the above number. Will arrange for u. Costing wise, call as well.
For 4AT, rpm is cut at 7500. After remapping, cut at 8500rpm.
Sam, u no need, urs is oredi done by KS.
Old Jun 7, 2006 | 02:22 AM
lennon's Avatar
Are they coming to SG again in the future??? reduced the temp by just adjusting ecu??
Old Jun 7, 2006 | 02:58 AM
rx8-8888's Avatar
Coupe07, Im from Malaysia. Can i drive down to sg to get it tuned? If can i will call you at your contact no. to get it arranged Thanks in advance. Or can he sell me a RE-Amemiya ECU ? coz i intend to get 1 but in Malaysia we have to order which takes a ridiculously long time.
Old Jun 7, 2006 | 06:38 AM
- D i a b l o -'s Avatar
Yea,i want to get one for the 4AT DSC variant.I presume mine is a Type E model.
coupe07 taukeh.Please do something :D
I got the money,just cant wait thats all.
I asked around for the mine reflash thingy,it'll take around 2 months "at list"..jeez
btw im from malaysia too.
Old Jun 7, 2006 | 08:38 AM
coupe07's Avatar
SC 300HP!!
yes, juz adjusting ECU. Next time shld still be coming.
as for when..... that's the question mark.
Old Jun 7, 2006 | 08:41 AM
coupe07's Avatar
SC 300HP!!
call office at +65 67474 360. Its either thursday or friday ONLY. Strictly by appointment. No walk-in will be entertained. I hope you guys understand.
Impossible to send u a new ecu.
Old Jun 7, 2006 | 08:43 AM
coupe07's Avatar
SC 300HP!!
I can only suggest u drive down to singapore. Get it done on the same day.
Old Jun 7, 2006 | 10:13 AM
watoke's Avatar
RX-8の魅力満載
Ivan, can sms me the cost for the re-mapping & adding the additional ECU, i am interested. Thanks
Old Jun 7, 2006 | 12:38 PM
coupe07's Avatar
SC 300HP!!
there is no additional ecu. remap ur ORIGINAL ECU. MM cars are not so affected. moreover, u risk ur warranty. PI cars are prioritised in this case bcos of their speed cut... let me see how much cars they can do tmr.... u willing to risk ur warranty??
Old Jun 8, 2006 | 12:10 AM
lohsk's Avatar
"Beng Your Ride"
I am the first on the road (auto) with the this ECU upgrade... And it's good...
Thanks to Ivan and the RE guys....
ok... 4 things they say the upgrading will do...
But what you also get is the brand new mapping from Mazda.... and the car runs really smoothly with this mapping..... later tonight I'll be testing on the roads after my meetings. All you guys with PI (Auto) cars... get your rides down and get it upgraded because this is the latest software for your ride, most probably your PI will not be able provided you with this service. And nobody can do a better job.
It takes time.... they they have to strip your ECU to the Board and then solder a port on to the board so they can do the remapping, this whole process will take some time, so only a limited cars per day.
Old Jun 8, 2006 | 03:06 AM
noob question
what is PI and MM? It applied to all the cars imported all around the world?
Old Jun 8, 2006 | 03:26 AM
whiteX's Avatar
gabrielc
wow! wat abt rpm cut for manual? 10,000 rpm?
Old Jun 8, 2006 | 03:28 AM
coupe07's Avatar
SC 300HP!!
noob question
PI = parellel import
MM = Mazda motor singapore
coupe07's Avatar
SC 300HP!!
Rpm cut for manual not so much of an issue.
Old Jun 8, 2006 | 03:45 AM
CoupeM's Avatar
Night Rider
bro u wan 10000rpm for wat? after 8500rpm power start sliding down liao.
Old Jun 8, 2006 | 04:03 AM
tems900's Avatar
If, No fuel cut, No RPM cut, with Fuel & Ignition tune, with 3" main pipe catback exh. & 3" highflow Cat. pipe & maybe intake, u still can feel the pull above 9K, but that danger zone for e apex seal
Old Jun 8, 2006 | 04:24 AM
whiteX's Avatar
gabrielc
ha... how would i noe, coz u said reduce rpm cut mah. aniwei. tis kind of tuning cost how much? 3-5 hundreds? or up to 1k? juz wondering... so actuali for manual its mainli for e speed cut and improve fuel efficiency plus lower temp
Old Jun 8, 2006 | 05:27 AM
tks coupe07,now how much would it cost.and how can i contact you?
Old Jun 8, 2006 | 09:18 AM
8citing's Avatar
Had my ecu remapped with RE AMEMIYA mappings today. Most distinct behaviour change is that the idle rpm (in D gear) drops to 500~600 range. When in "P" position, rpm hovers at abt 1k. No noticeable increase in vibrations as b4 reflash, when the idel rpm was at 650~700 all the time.
On the road, the car is more driveable and more eager/quicker to pick up (sublime effect of RE AMEMIYA sticker on ecu?).
As for all the touted cuts in speed/rev/fan/fuel, I wouldn't harp on them. End of the day, this is the only reflash which (correct me if I'm wrong) is available locally, and it makes the car (at least mine) more spiritually aspired. No regrets on the additional cut (pocket).
Old Jun 8, 2006 | 10:38 AM
coupe07's Avatar
SC 300HP!!
tmr is the last day and the schedule is very tight. Its either u drive down to spore or lose the opportunity. The telephone number is listed on the 1st page for contact purpose.
Tks for enquiry.
