Steering Tilt
Old Jun 5, 2006 | 09:34 PM
theclaytaurus's Avatar
Better than you
Steering Tilt
I tried my best to search for a related thread, but only found the standard bitching about no telescoping.
My tilt-lock lever on my steering column worked itself loose enough so that when I went over a bump, my steering wheel popped up. I had the dealership tighten it down, but I can already feel it loosening back up. Does anyone know of a long term solution, or is the thing just a piece of **** that needs to be tightened every so often?
It should be noted that I like the steering wheel low, and have to raise it to get my legs in and out of the car, so it is getting a lot of use.
Apologies if this is a repeat, and thanks in advance to anyone with any info.
Old Jun 5, 2006 | 10:11 PM
yiksing's Avatar
the giant tastetickles
If you had to adjust it every time you drive then I think its only reasonable the **** needs to be tightened all the time. Bottomline you have bad driving position.
Old Jun 5, 2006 | 10:16 PM
moRotorMotor's Avatar
Rotary eXperimental-8
I don't believe the tilt feature is designed to be used every time you get into and out of your car. Tilting it so far down that you have to raise it again before you get out of your car is a little much. Like yiksing mentioned, if you use it radically like that, prepare to perform frequent maintenance. It pays to play.
Old Jun 5, 2006 | 10:27 PM
CosmosMpower's Avatar
1935 lbs. FTW!
That doesn't sound right, I leave mine all the way up and lock it. I think it's the perfect position for daily and autocross and i'm about 6'0 and like to drive sitting fairly straight up with my arms crossed my wrists hit the top of the wheel.
Old Jun 6, 2006 | 12:50 AM
tjbourgoyne's Avatar
tjb
Can't you put the seat back instead of adjusting the steering wheel.
Old Jun 6, 2006 | 12:54 AM
\\Konig\\'s Avatar
turrrbo!
Its not the "piece of ****'s" fault, its your fault.
Old Jun 6, 2006 | 07:39 AM
Better than you
OK guys, so I'm a piece of **** driver. Yikes. This is the first time I've ever had a problem with a tilt coming loose on any car. It's like steering-wheel tilt locks are your girlfriends or something; so sorry to offend! Question withdrawn.
Old Jun 6, 2006 | 03:47 PM
stickman's Avatar
This may sound crazy but I think if you lubricate it some it will be less likely to work itself loose as often. The constant movement of the material against itself is what is working it loose, so some lubrication will mean less friction and perhaps less often need to tighten. It should still lock the wheel in place even with some lubrication.
Old Jun 6, 2006 | 04:01 PM
Haze's Avatar
Personally, I'm with it's a piece of **** camp. OK, so no "normal" person adjusts the tilt every time they get in and out of the car, but it is a tilt feature, and all he is doing is tilting it. Think if he was sharing the car with a really short wife. They would be doing the same thing so that each of them could be comfortable. No, I think that it shouldn't be loosening up no matter what, and since this is a safety hazard (popping up while driving) you need to have it fixed. If you are still under warranty, this is a slam dunk. just take it to the dealer and have it replaced (I would also stop adjusting it so much if I were you after it gets replaced).
I like the idea of lubricating it. Unfortunately, I think that that boat may have sailed since the unit is already loose, but certainly worth shot.
Old Jun 6, 2006 | 07:41 PM
Better than you
It's a nasty habit I have, but I'm trying to break it. I just never had a car with a tilt lock that worked itself loose at all, let alone so easily. The dealership is more than happy to replace it, so if it comes all the way loose again I'll have 'em do it. But I do agree with you, having a pre-determined number of tilts seems like a bit of a design flaw, especially since it's not the case in other cars. But hey, if I can just beat myself into not putting the wheel back up it shouldn't be an issue.
And sharing the car. Ha! That's a good one.
And thanks for the lubricating idea stickman, a no brainer once you point it out.
Old Jun 6, 2006 | 08:12 PM
NgoRX8's Avatar
i leave mine all the way down, but im short too. it shouldn't be used all the time, just set to ur specific liking. if you need to raise it everytime you get out, then i think you should learn to drive with it up.
Old Jun 7, 2006 | 07:54 AM
Haze's Avatar
Disclaimer: I assert sharing the car as merely a theoretical possibility and not in any way a practical potentiality.
Old Jun 7, 2006 | 05:56 PM
stickman's Avatar
Share and car are two words that should never be spoken in the same sentence.
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Evan Gray
Sep 26, 2015 12:30 PM
Wurromurro
Sep 20, 2015 05:02 PM
