View Full Version : Instant Mobility System Repair Kit
tbos1
06-04-2006, 06:38 PM
Probably have been other threads about this but haven't seen any: anyone had any good/bad experiences with the factory repair kit? Work alright or is it worth getting a spare?
I do make some long distance trips occasionally and don't want to deal with having to get it towed someday.
Thanks-
dtorre
06-04-2006, 08:58 PM
My IMS kit was a piece of shiat!!!....finally got it onto the tire and tube somehow ripped out of its place so when I squirted the fluid...all the crap squirted around the sides of the straw and went everywhere...still haven't been able to get the stain off my wheel!!!
New Yorker
06-06-2006, 07:46 AM
Mine worked perfectly. One thing, though… opening that kit is like opening the minibar at a hotel. $$$ You'll have to replace—not just repair—the tire ($230), and get a new can of sealant ($85).
If you get the spare, you can simply drive—slowly—to the nearest gas station and get the tire plugged for $20. But the spare takes up space in the trunk. And where will you put the flat tire when your 8 is packed for a long distance trip?
IMS Kit:
+ More space in trunk
+ On your way faster than changing the tire (but not by much)
+ Don't have to deal with changing a tire (empty trunk/take out jack/remove spare/get dirty in business clothes, etc.)
+ Don't have to put dirty flat tire inside car (if trunk is packed)
+ For purists, car handles a bit better without spare hanging back there
+ Sealant-filled tire drives better than wimpy emergency spare
+ Sealant-filled tire LOOKS better than wimpy emergency spare
- EXPENSIVE TO USE!
Spare:
+ Saves over $300
FRANCES
06-15-2008, 11:05 AM
I picked up a huge nail in edge of tire sidewall that came out on the highway. Used IMS and it leaked all over the place, and didn't seal the hole at all. Luckily I had an air tank as I was on my way to the race track, and was able to limp home, filling the tire 3 times to get 40 miles. I cannot justify $100 dollars for IMS replacement and am going to get a can of fix a flat instead.
alphamale
06-16-2008, 04:56 PM
Does a can of Runflat work better than the tire repair kit?
FRANCES
06-16-2008, 05:15 PM
I talked to the rosenthal mazda guys and they say that fix a flat can stick to the wheel and not come off, this might ruin the rim.
I just bought a spare tire/wheel and the mount on ebay, problem solved!
Cheers
alphamale
06-16-2008, 05:37 PM
Cheers
So what happens if you need the space in your trunk? Wouldn't runflats be a viable solution?
xsnipersgox
06-16-2008, 05:40 PM
i like it.. the lil air compressor comes in handy @ autocross lol
FRANCES
06-17-2008, 06:50 AM
How far do you want to go on a run flat. If they were that good DOT would mandate them. Spare tire was still cheaper than buying run flat tires at all four corners. If I need the room though, its pull it out and pray.
FRANCES
06-17-2008, 06:53 AM
Yeah, that thing sure is high output, you could adjust your tire pressure just before the compressor burns itself up. Oh did I mention that the stem core tool is a joke and broke in the stem? Yes, had to get a tool from a kid on a bike.
xsnipersgox
06-17-2008, 08:48 AM
i dont' know, all i ever had to do was pump it up after autocross to go home... i dont' know about u, all i ever have to do during the race is deflate pressure, never had to pump air in.
restiller
06-17-2008, 02:05 PM
I've only used the compressor in the kit to reinflate the tire after plugging up a hole with a camel strip. So I added the remaining strips and those screwdriver-like tools to my kit. I'm hoping to never use that sealant can.
TZ250
08-31-2009, 09:09 PM
Motorcycle guys use these. They're made for auto and moto apps. WAY BETTER than squirty goo slimy sealant. They work great on a tubeless bike tire, don't know how they'd do in a car tire.
http://www.stopngo.com/automotive.asp
