Need help with LC-1 install
Old Jun 2, 2006 | 01:50 PM
Sopheak.Reach's Avatar
SHOW STOPPIN'
Question Need help with LC-1 install
I'm planning on installing an LC-1 but got lost.
Does anyone know where the 7 wires go exactly? I've read the manual but some parts were unclear. Mainly on the white, yellow, brown, and green wires.
I also have the XD-1 gauge that comes with it, and an interceptor-x.
Old Jun 2, 2006 | 06:25 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
you know innovate has a forum for this over at innovatemotorsports.com (or what ever their url is.) The instructions are terribly simple. Perhaps a second read is in order?
As I remember you dont need to connect the yellow or brown unless you have some other device that you want to feed afr into, like an e-01, or perhaps the int-x. Isolate them if you dont need them.
THe green wire is your return ground for the analog outs. If you use it, ground it with the white wire (the system ground) and the ground of the item to which you are sending analog data.
The white wire is your system ground. Just ground your green and white wires some where other than the heater ground to avoid generating data noise.
Basically, this is exactly what the manual says. I dont know how to be more clear. Try asking a specific question about individual wires if this does not make sence.
Old Jun 4, 2006 | 10:24 PM
SHOW STOPPIN'
cool thanks. Just making sure.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
