Rear Koni Sport Shock Adjustment
Old May 31, 2006 | 09:52 PM
phillybudman's Avatar
I just put Koni Yellow 8240 1227 Sport shocks on the rear. Can they be adjusted by removing the lower mount only and compressing the shock. I e-mailed the Koni reps and they said yes but every thread I've seen here says it can't be done and that the shock has to be removed from the car. thx.
Old May 31, 2006 | 09:59 PM
Winning 8's Avatar
Hot Pit
no, you have to take out the shocks to adjust it.
Old May 31, 2006 | 10:00 PM
tiggerlee's Avatar
May Cause Anal Leakage
^ Yep. That's what I was told when I had mine installed. Only the fronts can be adjusted while on the car.
Old Jun 1, 2006 | 10:00 AM
apotocki's Avatar
I also have Koni's....rears must be taken off to adjust...I was fortunate to install mine 1 turn up from full soft and very pleased....with Eibach springs.
Old Jun 1, 2006 | 03:15 PM
Thanks for the feedback. I have them set at 2 tuns from full soft and I want them a little softer. I'll try 1 turn softer on Sunday.
Old Jun 1, 2006 | 04:32 PM
brattesani's Avatar
broken swaybar king
the rears DO NOT need to be taken off to adjust them. you need to take off the wheel and the gold plate in the trunk around the shock tower, then use a jack to compress the shock and jam a peice of wood or metal in betweet the spring and shock tower under the car. then the shock is low enough to be adjusted from the trunk. lazy people always win.
Old Jun 24, 2006 | 11:15 PM
I recommend putting them at 50%, which is 1-3/8 turns (2.75 turns full soft to full stiff)
if you need more than this then IMO you don't have the alignment adjusted properly
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Paul_Y
Sep 21, 2015 02:23 PM
