CZ unit vs stock ecu
Old May 30, 2006 | 06:35 PM
j_s2000's Avatar
Does the stock ecu overwrites the CZ map after a while?..i searched and couldnt find an answer....also does the pre-loaded map have adjusted timing already?
Old May 30, 2006 | 07:17 PM
cleoent's Avatar
n00b
search harder or better.
Old May 30, 2006 | 07:24 PM
Depends on how you tune it If you tune in open loop you're OK...if you tune in closed loop areas it will trim them out.
"Stage 2" maps have timing adjustments in the map....
Old May 30, 2006 | 07:35 PM
j_s2000's Avatar
hey, dannobre, i am a noob, so i dont want to mess with the timing, does that unit that i am buying from you have pre-adjusted timing already?
thanks
Old May 30, 2006 | 07:51 PM
I can load a map without it if you want...
Old May 30, 2006 | 10:57 PM
j_s2000's Avatar
does the stock ecu overwrites the CZ map after a while?
Old May 30, 2006 | 11:22 PM
Nemesis8's Avatar
Bigus Rotus
See this post
Old May 30, 2006 | 11:25 PM
j_s2000's Avatar
im sorry, but what's "open" loop vs "close" loop?
Old May 30, 2006 | 11:27 PM
Nemesis8's Avatar
Bigus Rotus
Ah grasshopper - you need to read CZ tuning for dummies
Old Jun 4, 2006 | 05:50 PM
dastallion951's Avatar
"open" loops where ur just using all the sensors to calculate the A/F ratio..... however in "closed" loop, thats where ur PCM looks at the O2 sensor n will use that to calculate the air fuel ratio......
Old Jun 4, 2006 | 06:57 PM
MazdaManiac's Avatar
^^ Uh, no.
Old Jun 4, 2006 | 09:38 PM
"open" loop is where the ECU determines how much fuel is added with no feedback from the O2 sensors...."closed" loop is where the O2 sensors "feedback" info to the ECU so it can adjust to a specific A/F ratio
yurcivicsux
192
Sep 12, 2017 10:54 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
RenzoRx-8
Sep 9, 2015 02:38 PM
mattymack
Sep 6, 2015 10:33 PM
