help to install the revi air duct.
Old May 26, 2006 | 03:53 AM
gerry76's Avatar
Hi Guys,
I am ready to install my Racing beat duct,but now i have a doubt.I have read the instructions,but not it come explained if I must to remove the bulkhead in the low part of the grill.My car to difference of that one shown in photo,it is completely sluice from the grill that it is uniform in 2 parts and in fact I don't see the radiator.If someone has mounted it,can show one photo of the grill?Thanks in advance for your help!!
Old May 26, 2006 | 06:08 AM
The Ace's Avatar
Greek Power
When you remove the bumper, you will see exactly where the duct will be. The opening will be EXACTLY behind the lower part of the front grille, in which case you have to remove the small plastic piece that sits there
Old May 26, 2006 | 10:26 AM
staticlag's Avatar
The Professor
Originally Posted by gerry76
Hi Guys,
So the plastic grille is completely solid on your car?
What year is your car, did you buy it used? Is there an aftermarket front already on the car?
Old May 26, 2006 | 10:50 AM
RA-Eight's Avatar
Scuderia
Yikes! Is that plastic covering a europe-spec thing?
Old May 26, 2006 | 11:57 AM
gerry76's Avatar
Hi guys,
yes my car(Eu spec My04),have the plastic grille that cover all the mouth.Us model have only the upper side?
Old May 26, 2006 | 12:06 PM
NgoRX8's Avatar
yea there is nothing there on US spec
Old May 26, 2006 | 12:15 PM
RA-Eight's Avatar
Scuderia
Looks like you'll just have get an aftermarket bumper. At least that's enough justification for me..
Old May 26, 2006 | 03:37 PM
gerry76's Avatar
Hi guys,
my bumper is absolutely stock.I have controlled today,in the lower side my grille is sluice,except in the sides,where there are two holes.I enclose a photo of my grille.
Old May 26, 2006 | 03:47 PM
mysql101's Avatar
See how the bottom of the honeycomb area curves upwards?
On the US-spec bumper, that area is open, so the air duct gets air blown in directly.
Old May 26, 2006 | 06:00 PM
If your absolutely sure it is solid like the silver photo the drill some holes in the black plastic between the diamonds. If you want you can just finnish it off with a dremel tool to make a perfect diamond pattern.
I just found this is only a USA part is not meant to be marketed on Europe.
However your distributor should have let you know what to do.
Also, there is a bracket differance.
Just minor little fixes will yield great results from the duct.
Old May 29, 2006 | 11:12 AM
The Ace's Avatar
Greek Power
Hi guys,
And I tell you again -and for all of you to know- that the plastic behind the front grille is NOT one piece. It's actually two pieces: the top half which is hard plastic for the licence plate to bolt on, and the lower half which is elastic plastic, which can/must be removed (it takes about 30 seconds).
I know from experience
Old May 30, 2006 | 03:42 AM
gerry76's Avatar
RevMeHarder
Jun 1, 2026 02:30 PM
8is>enuff
Sep 24, 2015 08:57 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
