Question about running rich
Old May 24, 2006 | 12:53 PM
trustbuddy's Avatar
Maybe this has been answered before....but...
if the renesis is tuned from the factory to run rich, isn't that potentially bad for the engine's life in the long run?
I'm from the honda world so some of you may understand my concern regarding running too rich....i actually killed two brand new cats in my previous integra because i was running rich....also, from my limited knowledge about cars, running lean(er) should make more power as well.
I just wanted to make sure because I'm thinking about getting the CZ to re-do the a/f ratio.
Old May 24, 2006 | 01:53 PM
Aseras's Avatar
rotaries run MUCH hotter than a piston engine.. running them rich cools the exhaust, which will make the cat last longer... the exhaust is still hot enough to cook off excess without damage to the cat. the only reason it runs rich is emissions.
by all means lean it out, you will get more power. you might light off the cat and cook it though, so keep it slightly rich if you actually care.
mazda is only running it this rich because of emissions.
Also make sure you have the latest PCM update. they fixed a lot of the problems and did lean it out better since M on.
Old May 24, 2006 | 02:19 PM
trustbuddy's Avatar
thanks for the reply. i'll take note of it.
Old May 24, 2006 | 03:02 PM
skwidd's Avatar
ZEE-non
What's the date of the latest PCM update? (Yes, I could search...probably)
Old May 24, 2006 | 04:50 PM
Old Rotor's Avatar
I just had mine in for the Hard-Start TSB. They said they loaded the latest PCM and it is the best tune yet! Smooth.....
Old May 24, 2006 | 09:06 PM
Brice-RX8's Avatar
Unless you are idling. I find the "R" flash is a little rough in the idle area. I thought the "P" flash was better for idling.
Billy Marcial
Mar 1, 2018 06:50 AM
Kanthinar
Dec 21, 2015 01:24 PM
9krpmrx8
Nov 5, 2015 11:45 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
yapakanichi
16
Jul 28, 2015 03:44 PM
