RX8 A/T w/ Intercpetor -X
Old May 24, 2006 | 12:29 PM
spr grn8's Avatar
It's Super Green...
Ok, Since i was one of the 4 people to install and tune my RX8 when Scott was out here in So. Cal, I thought i'd drop some thoughts and impressions also for the AT community.
Some of my experiences and results in my car are similar if not the same as DaveFzr wrote about in his first impressions thread. Of course HP's will be different, but the results are very comparable.
One of the first things to notice was a much smoother transition between gears both in auto and manumatic. But more impressive and noticeable was how soon i am going thru the gears. I know Scott will tell you that the Inter-X doesn't change when the transmission shifts, its my impression that the criteria that causes it to shift is occurring much sooner. For example, in auto mode i was at about 28-30 mph and @ 3000 rpm when it would shift from 1st to 2nd. Now it shifts into 2nd before im at 20mph and is at 3000-3200 rpm, when it goes to 2nd its already at 3k rpm and is rolling up the rpms rapidly and im in 3rd a few seconds later. The whole time the feel of the car pulling harder. The responsiveness is always felt as well. Be aware im not "racing" to get to a higher speed, im just driving normal, not babying it or racing it. In auto mode it gives you the feel of the gears are much shorter than before.
If i use manumatic mode im in higher rpms much quicker as well. I can roll up to the beep and shift into 2nd with a noticeable feel of increased torgue. When i shift to the next gear the car shoots into the next rev range without losing any of the torque pull. And 3rd gear is a whole new experience as it is strong all the way thru high rpms, and with shift paddles this car is really fun! You are able to set the rev limiter which cuts fuel with the Inter-X also, so i set mine to allow me to beep shift without cutting off the fuel, very nice!
My plan was to get the Inter-X because i plan to go with a SC when they are available. But with the Inter-X and a hi-flow cat there will a huge difference for this car.
I believe my dyno numbers to start out were @130hp and tuned it finished at 143hp. I dont remember what the torgue results were, but they increased as well. With a Hi-flow cat adding @ 10-12 and a SC, this car could easily see Hp's over 200. At least thats my plan. wish me luck!
Old May 24, 2006 | 12:39 PM
cleoent's Avatar
n00b
Great write up! I'm sure the AT folks will really appreciate it.
Old May 24, 2006 | 01:29 PM
DreRX8's Avatar
Good news--keep us posted...I too want to follow your lead once my warranty is up.
Old May 24, 2006 | 01:56 PM
spr grn8's Avatar
It's Super Green...
Thanx. I will try to keep everyone updated. I will be continueing my observations and how it behaves, as well as a little more fine tuning. I want to set up my cruise values this weekend. I think i can get a little better mpg too.
Old May 24, 2006 | 03:33 PM
mikeb's Avatar
100% Italian
how much does this cost
Old May 24, 2006 | 05:15 PM
spr grn8's Avatar
It's Super Green...
You can check with Mazsport for pricing, it is about 1600 for the computer I believe.
Old May 24, 2006 | 05:32 PM
therm8's Avatar
Bummed, but bring on OU!
You wouldn't happen to have a pic of the before and after dynos would you? I'd like to see the stock one (don't get to see many) and the mid-range gains.
I wonder if bumping the limiter up to about 8000rpm would help. My car is still increasing it's pull as it passes redline. There seems to be more power to be tapped up there.
Old May 24, 2006 | 08:57 PM
R888's Avatar
WedsSport Member
I tried stay up to 8100 rpm in 2nd shift in my 04 (they got 4 speed) then u can hear the beep already. Immediatley I shift, u know there will be 1-2 secs delay. Thats the highest rpm I got and I don't intend to over run the engine since I still got 50k to go b4 the warranty is up.
200 HP will be a good news.
I think there should be a way to override the odmeter and the ecu. I don't know if 4 port is a fact and a single oil cooler. The car has its potenital.
Lets keep our dream alive. I am sure something is up pretty soon.
Is the SC readyyyyyyyyyyyyyyyyyyyyyyy?
Old May 25, 2006 | 01:51 AM
FASTNMEAN8's Avatar
WHO's WANKEL?
this helped me a lot, as I posted in the aftermarket forum, i'm looking to buy a brand new Interceptor X..... Now I'm def. going to buy it.... thanks Spr grn8...
Old May 25, 2006 | 11:31 AM
spr grn8's Avatar
It's Super Green...
Originally Posted by therm8
...I wonder if bumping the limiter up to about 8000rpm would help. My car is still increasing it's pull as it passes redline. There seems to be more power to be tapped up there.
As a matter of fact that is where i set it. It was noticeably smoother with no cut out.
The way i would describe it now is, I can complete my Rev/Shift without interruption.
Old May 25, 2006 | 11:41 AM
spr grn8's Avatar
It's Super Green...
We did the dyno runs on two different dynos over the two days. The first machine had me at @ 135 stock. That dyno was reading 5-7 hp's higher than the 2nd dyno.
i finished @ 143 on the 2nd dyno. The numbers were consistently different between the 2 dynos on all 4 cars. That leads me to believe that on the 2nd more reliable dyno i was at @ 130 stock and tuned i was at 143. When i get the dyno report i will put something up.
Old May 25, 2006 | 07:19 PM
Renesis_8's Avatar
Just curious, what RPM did you make that power, does it continue to make power after 7500rpm, the redline for auto?
________
Headshops
Old May 26, 2006 | 11:51 AM
spr grn8's Avatar
It's Super Green...
I believe the rpm was between 6k- 7k. I will have to check the dyno report. The power was at the top end, and as it neared redline might have tapered off just a bit, if i recall correctly.
Old May 29, 2006 | 10:39 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Nice write up. I owe you some pictures. I haven't forgotten just got yanked in 100 diffrent directions.
i expected a little more at the wheels in stock form.
Now if Paul Yaw would build a nice flowing header that would help our low end, then we would start to see more benefit from the 4 port NA renesis that has a after market computer attached.
one more thing Yaw built a 4 port w/ a Motec and headers. Output = 238 hp (low/mid rpm range) at crank.
Hmmmmmmm. We are getting closer people.
just give it time for it to be done right.
Old May 30, 2006 | 03:14 AM
DOMINION's Avatar
I don't buy Kool-Aid
Thumbs up
Dam good job my friend. My hope too is for my car to acheve 200hp. Well done.
Old May 30, 2006 | 08:20 PM
kowzan5's Avatar
hey i have a question for u have u tried up'ing the RPMS up to 9000, with the interceptor-X?
Old May 31, 2006 | 11:46 AM
spr grn8's Avatar
It's Super Green...
I have not. I didnt see the benefit or any increase of HP that high and didnt want to stress the engine or tranny unduely.... That doesnt mean it cant be done.
Old May 31, 2006 | 06:22 PM
R888's Avatar
WedsSport Member
The cut off is 8100 rpm, I tried it already.
Old Jun 1, 2006 | 07:49 AM
zaku's Avatar
車の性能の違いが戦力の決定的差ではない ということを
Is it (interceptor-X, AT version) out for purchase?
Old Jun 1, 2006 | 12:15 PM
spr grn8's Avatar
It's Super Green...
I believe there is only one type of Interceptor-X. The maps you build or load are what defines how it runs in an AT. It also goes for every individual RX8 out there. But Scott at Mazsports may be able to tell you more if i am incorrect. So yes, I bought an Interceptor-X for an AT.
Old Jun 1, 2006 | 08:24 PM
presequel's Avatar
ay bay bay
so do you have the hi cat flow right now or are planning to add with supercharger?
also, how was the install, was it hard? how long did it take? tuning? is it something a noob can do himself or better to bring it somewhere to install.....thanks.
Old Jun 1, 2006 | 11:00 PM
R888's Avatar
WedsSport Member
I think is wise to invest the money when the SC is out, when the SC is out there, there might be something coming up to boost up the sc as well. Since now the interceptor-X has made the AT gain only 15 max @wheel, correct me if I am wrong on that.
Of course, 15 + another 10 for the Super Cat, exhuast, RB intake and maybe header. = 25
130 + 25 is = 155....
Any guys has run the dyno with 160-180 @ wheel? If yes, it is worth to invest. Remember after all this money invest, u are just only as fast as the manual.
Anyone now? tuned with at least 160, let us know the da vinci code!!!!
Old Jun 2, 2006 | 11:50 AM
spr grn8's Avatar
It's Super Green...
I plan on getting a hi-flow cat next, soon. And yes, then a SC.
The install was very easy, you must follow the instructions exactly. Anybody should be able to do it. Make sure you read the instructions first!
As far as tuning, once you become familar with the software it is easy to move around in it, and changing a value is as simple as hitting the up or down arrow on your keyboard to make incremental adjustments. The problem with tuning comes from not knowing if the baubble or burp or sluggishness is due to too rich or too lean a mixture and how much more or less to adjust. Thats where a accurate afr gage or experienced tuner is very helpful.
Old Jun 3, 2006 | 04:54 PM
09Factor's Avatar
Couple things you should look at.
1. pick up a LM-1 Wideband O2 sensor. Great data logging features.
Sluggishness usually equals rich
Baubble could be lean.
knock/ping == lean
But since your saying changing values is simple, try small increments in the area of the baubble/burp.
knowlege is power my friend.
Good luck.
Old Jun 5, 2006 | 07:35 PM
kowzan5's Avatar
any dynos or guess on what rwhp u r getting from your turbo'ed AT 8 yet?
