Air Filter - changing procedure
Old May 24, 2006 | 11:17 AM
clarencel's Avatar
as per the topic, i read the User's Manual to have a look at the air filter but had difficulty opening the filter cover. something seem to be blocking the way.
as per the manual the instructions (summarised) were
1. release the clips securing the box
2. unclip the electric connection
3. lift the lid
4. change the air filter
5. secure in reverse or of step 1-4
i did just that put stil can lift the air filter lid entirely. i can only lift the lid up to about 2cm. not sure what is blocking the way.
anyone has the same problem?
Old May 24, 2006 | 11:27 AM
mkl22's Avatar
its quite a pain to remove. you need to loosen the round metal ring clip on the air box side. then push back the box so that the front 2 ***** disengage from the slot. lift the front of the box up and then remove the rubber hose from the airbox. Be sure not to over stretch the other eletrical and tube connections. then unclip the 2 clips and remove the filter.
Old May 24, 2006 | 11:32 AM
clarencel's Avatar
thanks.. i guess i either didnt read the manual properly or the manual is a little inaccurate. wil try that.
Old May 24, 2006 | 11:51 AM
coupe07's Avatar
SC 300HP!!
dun have to loosen the metal ring. juz unclip, use a little bit more force, then take it out.
best is u have another person to help u.
Old May 24, 2006 | 01:39 PM
sqflyer's Avatar
Heavy Machinery Operator
Although it is possible to use some force to open the lid and squeeze the air filter out, I feel it is worthwhile and less strenuous to remove the entire air intake box. Can remove the filter with ease after that and can clear out all the 'stuff' inside too.
Old May 24, 2006 | 07:50 PM
DaveT's Avatar
I had the tech at the dealer show me recently. Simple.............
1. Grab the back of the air box and pull straight up to release the two rubber grommets in the bottom of the box.
2. Push the complete air box toward the back of the car to release the air inlet tube from the frame.
3. Open the box.
4. Install is the reverse of above steps.
takes about 5 seconds.........................
05TR1CH
Apr 18, 2023 04:56 AM
uZu
Dec 30, 2015 12:35 PM
GK1707
Dec 2, 2015 10:01 AM
Zank300
Aug 26, 2015 07:40 PM
MrORAN6E
Jul 24, 2015 09:32 AM
