midpipe or flywheel?
Old May 24, 2006 | 07:14 AM
rx808boi's Avatar
i wanted to get your guys opinion on this matter. I have to choose between a flywheel or a midpipe because my gf is pregant and i need to keep my money spending @ a minimum right now so i have no chose but to choose. Here are somethings that might help.
1. I have the ACT heavy duty clutch (pressure plate and disc) and i have the Greddy SP2 exhaust system
2. I am eventually going to have both of them @ some point but from the 2 what would be more affective in performance and response?
Thanks for your guy's thoughts
Old May 24, 2006 | 07:17 AM
cjkim's Avatar
^noob
so wait.. you want to BUY one of those two or you can only keep one?
Old May 24, 2006 | 07:25 AM
sstricker's Avatar
of course i searched!?
he wants to BUY one of the two, yes... after reading abbid's (i think) thread about his new flywheel....... i would say flywheel.
EDIT: Abbid's thread - https://www.rx8club.com/showthread.p...hlight=fidanza
Old May 24, 2006 | 07:49 AM
mysql101's Avatar
midpipe costs almost nothing ($200). flywheel costs about $300 - $400 (have to include cost of counterweight) and around $300 more for install.
So if you're looking to cut down on spending, the midpipe is the way to go.
Flywheel will give you something like 6hp in first gear, 3 in second, etc.
Old May 24, 2006 | 08:57 AM
yiksing's Avatar
the giant tastetickles
Flywheel coz I think midpipe are noisy
Old May 24, 2006 | 09:01 AM
SoFL_RX8's Avatar
Former Owner
Midpipe is more bang for your buck probably, but if your getting both on eventually I think its a matter of preference rather than performance. The difference in performance in negligible Id imagine.
Old May 24, 2006 | 12:06 PM
Fanman's Avatar
You do realize with a midpipe you are very likely to trip a Check Engine Light, not to mention may be very, very loud with the Greddy exhaust right ?
Old May 24, 2006 | 04:22 PM
rx808boi's Avatar
im goin with the flywheel then i mean i already have the ACT clutch I might as well buy the flywheel and install it all at once instead of seperate times (that would save me alittle money) and plus i heard the flywheel is most effective in the 8.
thanks guys
Old May 25, 2006 | 12:15 AM
toxin440's Avatar
neither.... use the money for an abortion, then you can afford a lot MORE things down the line
j/k bro good luck
Old May 25, 2006 | 12:48 AM
scsi's Avatar
are you from hawaii?
i plan on goin with the RP Supercat. i hear the high flow cat makes a great difference. should be like 8-10hp and its 11lbs lighter than the stock piece. seems like u shoulda gone w/ flywheel same time as clutch tho.
Old May 25, 2006 | 06:38 AM
rx808boi's Avatar
yea i should of but the place i bought it from was asking way too much so i decided to buy it seperate because i didnt have all the money at that time. im goin with the flywheel because i want better response for my 8.
Ovr-9000
Apr 7, 2016 11:19 PM
qtipconnoisseur
Oct 29, 2015 07:19 PM
br0wm
Oct 24, 2015 11:06 PM
xAgyex
Sep 28, 2015 08:54 AM
yapakanichi
Sep 25, 2015 07:55 PM
