Mazdaspeed Brake Pads
Old May 23, 2006 | 09:36 AM
Feras's Avatar
the Doctor
I just ordered myself some mazdaspeed brake pads. anyone else have these? pros cons? if i wanna switch brake fluid what should i go with?
Old May 23, 2006 | 02:51 PM
YaRiX8's Avatar
I have MS brake pads. I have done 2 track days with them. These pads do not stop the car better than the stock pads, BUT they stop it for much much much longer without fading!
No problems in snow days.
They are a little bit noisy, but nothing unacceptable
Brake rotors friendly.
Temperature range is from 0°C to 400°C.
I also use Motul RBF600 for brake fluid...it is the top for me.
Next brake pads will be EBC Redstuff...less dust, less noise, more performance but a little more unfriendly with brake rotors.
Old May 23, 2006 | 09:02 PM
BlueRenesis82's Avatar
Registered Tracker
why did you get the MS pads? there are better track pads for the same/less money. What did those bad boys cost you for a set?
Old May 23, 2006 | 09:46 PM
Ja, go with Porterfield Kevlar
http://www.porterfield-brakes.com/
While your at it get some fire retardant hose for the A/C line above the engine.
Use it as a wrap!
Old May 24, 2006 | 03:47 AM
YaRiX8's Avatar
Use it as a wrap!
What is the reference numbers for the porterfield kevlar pads (front and rear) please?
On their website they show different compounds, but with the same reference number...strange.
Old May 24, 2006 | 09:02 AM
Feras's Avatar
the Doctor
i wanted to go with a product that would keep everything down there under warranty and something i didn't have to install myself. about $300 for the whole job.
Old May 24, 2006 | 11:20 AM
Registered Tracker
wow, I know a set of Hawks HP+ only cost about $60 an axel thru rotaryextreme.com and to swap out the brake pads is roughly a 5 min job. It really is super easy.
Old May 24, 2006 | 12:10 PM
ZoomZoomH's Avatar
Mulligan User
*looks up*
holy jesus, $60 per pair for HP+ pads, goodbye carbotech, hello hawk!
Old May 24, 2006 | 01:15 PM
Feras's Avatar
the Doctor
the only vehicle i have ever made modifications to ran on a motor and was roughly 1/12 scale. A mechanic i unfortunately am not...and i sure as hell am not going to start my mechanical fiddling around with the system that allows me not to run into trees on my 30000 dollar sports car.
i'd like to learn how, but i dunno anyone nearby to teach me and i sure as hell am not going to an ITT tech place.
Old May 24, 2006 | 02:06 PM
Registered Tracker
lol, you know how to take off your wheels right?
Old May 24, 2006 | 11:06 PM
Feras's Avatar
the Doctor
well yeah but i imagine brake pads need to be situated just perfectly with adhesives and screws and such and have the proper gaps between rotors and all that fancy jazz...not just an in and out like a razor blade.
Old May 24, 2006 | 11:12 PM
yiksing's Avatar
the giant tastetickles
Its not difficult to swap pads as long as you have the tools, it was my first DIY.
Old May 25, 2006 | 12:14 AM
dsmdriver's Avatar
Nope- disc brakes are pretty much self adjusting. No adhesives, screws, or manual gapping. Just take off the tires, pull two bolts, swap out the pads, and reverse.
Old May 25, 2006 | 05:56 AM
rotor_man's Avatar
What are the Hawks like, im thinking about changing to aftermarket pads but don't want excessive rotor wear. i'm after something that has less dust. I'm happy with the current brake pads because i don't track my car
Old May 25, 2006 | 09:03 AM
Registered Tracker
then I would NOT reccomend the HP+'s, they are mainly track/autocross pads
Old May 25, 2006 | 11:57 AM
willhave8's Avatar
To your question, if you are not planning to do Autox or HPDEs etc., the stock fluid (DOT 3) will perform more than adequately for you.
Sinc eyou put on the MS Pads, I assume you are going to the track. But perhaps you just want to upgrade then get any DOT 4 fluids. the Motul 600 mentioned one, ATE Super Blue is another and the list goes on and on (FORD makes a less expensive DOT 4 fluid, Castrol LMA DOT 4 is also cheap). The choices within this area seem to come down to how often are you willing to change it and what exactly are you doing with the car. More high speed track time = changing more frequently...
Old May 26, 2006 | 09:10 AM
Feras's Avatar
the Doctor
yeah i experienced some pretty scary brake fade and i wanna say good bye to that...i'll be grabbing one of these DOT 4 liquids...how much do i need for one change (number of oz., Liters, bottles)?
Old May 26, 2006 | 09:16 AM
ZoomZoomH's Avatar
Mulligan User
1 1L can of ATE Super Blue is all you need to completely flush the braking system (actually you'll have over 1/2 can left after you're done)
Old May 26, 2006 | 09:18 AM
Asmoran's Avatar
^^ Zoom beat me to it
Old May 26, 2006 | 10:17 AM
BoosTED's Avatar
[QUOTE=MazdaspeedFeras]the only vehicle i have ever made modifications to ran on a motor and was roughly 1/12 scale. A mechanic i unfortunately am not...and i sure as hell am not going to start my mechanical fiddling around with the system that allows me not to run into trees on my 30000 dollar sports car.
i'd like to learn how, but i dunno anyone nearby to teach me and i sure as hell am not going to an ITT tech place.[/QUOTE]
Is there anything wrong with going to an ITT Tech place?
ATE Super Blue gets another bump from me.
Old May 26, 2006 | 10:38 AM
willhave8's Avatar
I chose ATE Super Blue based on confirmation that it works well and I like the idea of having 'Super Blue' in my car
Old May 26, 2006 | 11:56 AM
Registered Tracker
Motul 600 for me
hufflepuff
May 30, 2016 10:45 AM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
