Its almost time for a new battery
Old May 22, 2006 | 05:19 PM
R888's Avatar
WedsSport Member
Post Its almost time for a new battery
Guys please input some batterys info as follow:
Battery type
Brand name:
Weight:
Voltage:
Old May 23, 2006 | 11:19 AM
RenKat's Avatar
Optima Model 35
http://www.1st-optima-batteries.com/index.html
$124.95
Old May 23, 2006 | 11:52 AM
brillo's Avatar
Go Texas Longhorns!
Originally Posted by RenKat
ditto
Old May 23, 2006 | 12:26 PM
FastRX8's Avatar
IstanbulNotConstantinople
This is the Optima 35R. Fits perfect, and the post are on the correct side.
It's $139.69 at Summit Racing.
Battery type: 35R
Brand name: Optima Yellow Top Deep Cycle 12 Volt Batteries
Weight: 37.2lbs
Price: $139.69
Color: Yellow
Voltage: (this should say "Cold Cranking Amps") 650 amps
More detailed info -
Brand: Optima Batteries
Product Line: Optima Yellow Top Deep Cycle 12 Volt Batteries
Battery Usage: Deep cycle
Volts: 12 V
Battery Terminals: Top
Battery Type: AGM
Cranking Amps at 0 Degrees F: 650 amps
Cranking Amps at 32 Degrees F: 810 amps
Reserve Capacity: 98 minutes
Length (in): 9.312 in.
Width (in): 6.813 in.
Height (in): 7.625 in.
Quantity: Sold individually.
Notes: BCI Group 35
Battery, Yellow Top, 12V, Deep Cycle, Starting, 650 Cold Cranking Amps, Top Post, BCI Group 35, Each
- Cesar -
Old May 23, 2006 | 02:39 PM
alnielsen's Avatar
$119.99 @Jegs
Found with Froogle
Old May 23, 2006 | 06:07 PM
RenKat's Avatar
It's a Red Top.
You dont need the Yellow Top.
Old May 23, 2006 | 06:26 PM
lurch519's Avatar
www.evoperform.com
i used the stinger power 2 sp1000 battery. it is about the same size as the factory battery, weighs 37.8 lbs. 1200 amp for 5 seconds of cranking. with this battery, i have never had any issues with flooding, even when my roommate moved my car and didnt warm it up. only issue i had to use a piece of 3/4 to space it up , as it is shorter than the factory
projectr13b
Mar 1, 2019 09:00 AM
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
atmd
Aug 19, 2015 12:43 PM
mesaboogie
Aug 7, 2015 10:48 AM
T_Mags
Jul 24, 2015 11:29 AM
