install shocks and springs diy????
Old May 20, 2006 | 04:30 AM
for the ones who have done it....
what is easier????? the front or back????
i have read the diys... and am not afraid to do it... but warming up with the less dificult would be the way to go...
Old May 20, 2006 | 05:42 AM
NgoRX8's Avatar
when i did my spring install it was about even. but i didn't know much from the beginning. heh..
most have stated that the front is an easier install than the rear because the rear is multi-link.
Old May 20, 2006 | 06:10 AM
StealthTL's Avatar
Metatron
Post Install.....
Backs are easier than fronts, and less tension on the spring, so an easy gig.
Mark your rear alignment mark on the adjuster, so you know where you started from, you will need an align after, but you will be in the ballpark.
In front you have to remove the big bolt that holds the upper A arm on to the chassis - it looks like you don't need to, but you do. When you do, either remove the ABS sensor and clip it away from danger, or be REAL careful not to let the brake assembly hang on it. ($600 just for the wire harness)
S
Old May 20, 2006 | 10:26 AM
NgoRX8's Avatar
haha, ok. so what lazi told me is wrong.
the rear did seem easier for me, i just didn't know if it was because i did it after learning from the front or what.
Old May 20, 2006 | 12:27 PM
The front have higher pre-laod so they are a bit more difficult to put together. The install on the front is easier though once they are put together.
The rears are easier to put together...pre-load is less. They are a bit more of a PIA to get out of the car though.
You shouldn't have to remove the lower links on the rear......but it really doesn't matter as you need an alignment anyway. The toe changes quite a bit when the car drops even an inch.
Make sure you lower the car before you torque the suspension bushings if you can
Good Luck
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Paul_Y
Sep 21, 2015 02:23 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
