gcbutter
05-19-2006, 04:22 PM
1994 Touring RX7 Manual Transmission (Glass Sunroof):
Mileage: 56,xxx (odometer reads 13,xxx) Replaced by Mazda; Paperwork provided
Engine: Reman 16,xxx miles (Compression test done May 6, 2006 results:
Front 8.0 8.0 8.0, Rear 8.5 8.5 8.5.)
Regular maintenance:
Oil change every 2,000 miles
Fuel filter replaced (Feb 20, 2006)
Pettit PROTEK-R used at every gas fill-up (one of the reasons for the great compression results)
Transmission and Rear-End using NEO Synthetic (flushed/filled Dec 10, 2005)
Radiator Flush and Fill Done (May 7, 2006)
NGK Platinum 9’s all around (replaced May, 7 2006) “I Will include 4 new NGK Platnium 9’s with sale”
Aftermarket/Performance Parts:
GREDDY TD0620G Kit ($3150.00)
GREDDY Blowoff Valve ($200.00)
GREDDY Profec B ($400.00)
GREDDY Turbo timer ($100.00)
GREDDY SMIC ($1095.00)
GREDDY Elbow ($187.50)
APEXI-Power FC+Commander ($1200.00)
20B Fuel Pump ($265.00)
Magnecor 10mm wires ($80.00)
Autometer Boost gauge ($58.00)
Autometer Fuel gauge/lightshow ($80.00)
Racing Beat Dual Exhaust ($515.00)
Downpipe ($300.00)
Mid-Pipe ($150.00)
ACT 6 Puck Clutch ($556.91)
Kuhmo Tires Front/Rear ($724.00)
Rear Bushings replaced (Dec 01, 2006; There is NO clunking what so ever!!)
Slotted/Drilled Brembo Rotors & Hawk Pads replaced ($450.00)
New Wiring Harness (replaced when the reman was installed) $797.00
Front Brake Calipers, Lower-Intake Manifold, Upper-Intake Manifold & Throttle-Body are all polished
Double throttle Modification has been done to the UIM
Paper’s to Prove: $23,000 + (not including regular maintenance) has been spent on this car
Body Condition:
Exterior: 9 out of 10. (small dent on Drivers side, It’s smaller then a penny; see pic)
Under Hood Fire Sheet Thing has been worn due to the Turbo Pipe touching it (pic included)
The Stereo Antenna stopped moving up just recently. The motor still works, just the wire thing inside the antenna needs to be replaced.
Interior 9 out of 10. (Wear on Drivers side seat; see pic) That’s it, Interior is Really Clean!!!
I had the mirrors, rear spoiler, and rear bumper re-sprayed ($400.00) Other then that the Paint is Original VR. I also updated it with the Mazda flying “M”
My Impression of Car:
This is my second RX7. The first one I owned was an Automatic. After about a year with that one I sold it. Too many issues with it; and people trying to rip me off. So I vowed to get another RX7. After about 18 months searching I found this one in Houston, TX. I ended up flying there from South Carolina, and driving it back. What a drive that was, absolutely a thrill to say the least.
The Car has only been seeing 10psi of boost. You will see that the Boost Controller is set to the very lowest setting. Attached is the dyno sheet (312.3hp, 268.1tq) 4th gear pull. The Power-FC is still in it’s stock configurations (meaning it has never been tuned). The performance shop that installed it, increased the fuel setting (for reliability purposes) until a certified Apexi tuner can tune it. I had Steve Osley look at the Map for me, when he had the car. He saw no issue with it at all. Steve Also set the Radiator Fans to came on at (low) 80 degrees; (Med) 85 degrees. The car never runs hot!!
Other than the Stereo Antenna not going up, the car currently has Zero Issues! I welcome anyone to come by and check it out. Of course I will not offer joy rides to non-serious buyers.
PRICE:
$19,000
Pics and Videos can be seen here: http://www.putfile.com/gcbutter23
Downpipe ($300.00)
Mid-Pipe ($150.00)
Body Condition:
PRICE:
$19,000
