Clutch pedal
Old May 18, 2006 | 10:10 PM
mkl22's Avatar
Clutch pedal
Clutch pedal feels weird. when the car is cold, the pedal movement of the clutch seems to be progressive and require the same amount of force. After driving for a while, there seems to be some dead play before the pedal firms up. Have bled the clutch line. maybe incomplete bleeding?
Old May 19, 2006 | 11:03 PM
SomeGuy_sg's Avatar
Mm...That seem like a weird thing to have. What clutch fluid did you use ? It might be incomplete bleeding . But if it was that , the pedal feel would be the same, when the car is cold or warmed-up.
Did you bleeding according to the workshop manual ? Some times the simplest things are the most over looked.
Old May 21, 2006 | 01:31 AM
mkl22's Avatar
I think i know the problem. Throwing the pedal a few times will make it feel like normal again, regardless hot or cold. seems like fluid is inconsistent. I bled it the correct way using motulRBF600.
Old May 21, 2006 | 10:16 AM
SomeGuy_sg's Avatar
lol, so weird. You have to prime the clutch before use... Very race car-ish :P May be there are still trapped air pockets in the clutch ?
Old Jun 27, 2006 | 12:03 PM
mkl22's Avatar
think i have found my problem.
will try fixing it and see how it goes.
http://www.finishlineperformance.com...04-06-1641.pdf
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
