Will 18x9 in front and 18x10 in rear with a +45 offset fit?
Old May 16, 2006 | 02:06 AM
ShadyE's Avatar
Question Will 18x9 in front and 18x10 in rear with a +45 offset fit?
I was browsing the forums but I dont see anyone with this type of setup yet. Has anyone out there have any info about this or even if it will work or not?
Old May 16, 2006 | 02:09 AM
NgoRX8's Avatar
i don't know if you'll clear the brakes...
Old May 16, 2006 | 02:12 AM
ShadyE's Avatar
our offset is +50 so do you think it will fit? But not sure on the width? really want these rims but thats all the setup they have.
Old May 16, 2006 | 02:30 AM
NgoRX8's Avatar
our stock set up is 18x8 +50mm all around. you are going to lose 14 mm inner clearance up front and 20 mm inner clearance at the rear. don't think they'll fit.
Old May 16, 2006 | 02:34 AM
ShadyE's Avatar
ok thanks !
Old May 16, 2006 | 03:45 AM
lazi's Avatar
drivelinestore.com
we have high offsets. which is freakin gay hahaha
Old May 19, 2006 | 01:00 PM
Endless Rotaries's Avatar
Yes I've run that setup with 245/40/18 and 275/35/18. I had to roll the rear fenders about 3mm but it worked just great. That or just run camber. There's a decent amount of negative camber in the rear from factory anyways.
Thanks, Rishie
Old May 22, 2006 | 06:05 AM
RX4life's Avatar
yes ... it.... will.... fit!
Old May 22, 2006 | 02:06 PM
BIU's Avatar
BIU
I have that setup and yes it will work
https://www.rx8club.com/showthread.php?t=88750
Old May 23, 2006 | 10:00 PM
I have 45mm offset with 18X7.5 and many other people run with 35 mm offset.
It all depends upon wheel design.
Billy Marcial
Mar 1, 2018 06:50 AM
Modified Dave
Aug 20, 2015 07:38 PM
R2D2X8
Aug 17, 2015 08:47 AM
Brandonien
Jul 30, 2015 12:33 PM
