Brake Fluid
Old May 15, 2006 | 01:10 PM
92tsiawd's Avatar
Brake Fluid
After 3 lapping days, I need to replace my brake fluid. How much brake fluid do I need? Also, I was thinking of getting redline but any other brands you guys recommend?
Old May 15, 2006 | 01:21 PM
expo1's Avatar
He's as bad as Can
Are you using DOT 3 or 4?
I put in ATE Blue DOT 4 in the spring and do about 10 track days till I swap it out for regular DOT 3 for the fall / winter. As for the amount that is what the Max line on the reservoir is for.
Old May 15, 2006 | 01:35 PM
92tsiawd's Avatar
haha, I know but just don't know how many bottles I should buy...is 2 bottles enough?
Old May 15, 2006 | 01:39 PM
expo1's Avatar
He's as bad as Can
My bad, ATE blue is sold by the liter, I get two. Better to have too much than two little.
Marc_GS's Avatar
Hooked on go-fast crack
I'll second expo's recommendation for ATE super blue.
It comes in 1L containers, and you'll only need one of these. I did the clutch and the braking system (including bleeding the master twice, as specified in the shop manual and recommended by people on this forum), and the container was still about half full.
Old May 15, 2006 | 01:43 PM
expo1's Avatar
He's as bad as Can
Another reason I like the ATE blue is that when I go back to DOT 3 in the fall I can easily tell when I got all of the Blue out and visa versa when I put it back in the spring.
Old May 15, 2006 | 01:46 PM
92tsiawd's Avatar
Nice, thanks guys, I'll try that brand out
Old May 15, 2006 | 02:54 PM
cleoent's Avatar
n00b
Uh we did 4 cars over the weekend with two cans of ATE super blue. That's complete fluid swaps.. 1 can will be enough.
Old May 15, 2006 | 10:03 PM
yiksing's Avatar
the giant tastetickles
Why did you switch out the DOT4 during winter?
Old May 15, 2006 | 10:16 PM
BlueRenesis82's Avatar
Registered Tracker
good question
Old May 15, 2006 | 11:27 PM
Winning 8's Avatar
Hot Pit
the ATE Super Blue, need to change it every two to three years. It is printed on the can.
ATE, Motul & AP, they are all the same, the brake fluide will trap moisture, and when it trap the moisture their boiling point will go down. so most racer will change brake fluide every race.
Old May 15, 2006 | 11:57 PM
It's so easy to do, change it after every track day.
You can see the difference in color after 1 track day.
Old May 16, 2006 | 06:11 AM
expo1's Avatar
He's as bad as Can
I should rephrase that to the ‘ off season’ (Track Days) , which for me is usually October-April. I have no need for DOT 4 during that time. Also for me it makes the change back in the spring easy. I do about 10 track days a year and change the trans, diff, and brake fluid (DOT 4 ) every spring.
Old May 16, 2006 | 07:27 AM
Spin9k's Avatar
Momentum Keeps Me Going
Huh? You mean your brakes don't get as hot on "off season" track days? How'd you do that? I don't like the idea of mixing different temp fluids repeatedly, even w/a complete changeover. Here's my switch between solution that solves that... "ATE Super Blue Racing and ATE TYP 200 are the same brake fluid in two different colors (blue and amber, respectively)".
Old May 16, 2006 | 07:36 AM
expo1's Avatar
He's as bad as Can
By off season I mean driving around NJ in the fall & winter no track days. I shouldn't post till after my second morning coffee. After October I drive like a granny till next April.
Old May 16, 2006 | 08:46 AM
John V's Avatar
Not ******
The benefit to the Typ 200 is that it doesn't stain the reservoir blue... :ack:
Old May 16, 2006 | 08:48 AM
yiksing's Avatar
Do most DOT4 last as long as DOT3?
Old May 16, 2006 | 09:02 AM
John V's Avatar
Not ******
DOT3 is an old, old standard. All new cars I know of specify DOT4.
If you have any DOT3 laying around, it should be thrown out.
All brake fluid is hygroscopic, the difference between brake fluids are the dry and wet boiling points. A good fluid for the street will have high dry AND wet boiling poitns, since the fluid is not changed as often. A track fluid that is changed frequently can get by with a high dry / low wet boiling point.
JV
Old May 16, 2006 | 09:08 AM
Old May 16, 2006 | 09:12 AM
John V's Avatar
Not ******
Originally Posted by TeamRX8
That beats the pants off the Ford HD fluid I've been using for years.
Pity it's four times the cost...
Old May 16, 2006 | 09:15 AM
you only have to flush 1/4 as many times too thanks to the 518 degF wet boiling point, I use 1 Liter a year so price-wise it's no big deal plus I don't have to mess with it I hate messing with brake fluid
Old May 16, 2006 | 09:39 AM
Imp's Avatar
Imp
What's next?
Saw this posted on another forum about a month or so ago...
Warning--> Ford PM1 brake fluid has changed
Since I have been a rather vocal advocate of "The Ford brake fluid formerly known as -- >C6AZ-19542-A"... (else where on the net) REPLACED BY PM-1(When switched to Motorcraft sourcing)
I feel obligated to warn of a recent change in the part number... and more importantly... It's dry boiling point reduction!!!(I'm a Ford/Linc/Merc parts guy)
PM-1 is now PM-1C
PM-1 had a D.B.P. of 550F
PM-1C has a D.B.P. of 500F
PM1C is the new number. BEWARE, the old stuff and new stuff are in the same plastic bottles. Both have the same wording on the front of the bottle. The dry boiling point is in the first line of wording on the back of the bottle. They look indentical.
Look 1/2 way down on the right column is the part number,
PM-1 FIR No.002092 the good stuff
PM-1-C FIR No 174922 the fair stuff
They even have the same bar code number 3150826582
It is a running change and there is still lots of PM1 in the system.
Just an FYI.
Old May 16, 2006 | 11:06 AM
tomfree's Avatar
And for any of you in the DC area, I've already called Darcars Ford in Lanham, MD, and they claim to have 22 cases of the old stuff. I'll be picking up a couple cases this week.
theblinkof
Oct 4, 2023 05:24 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
XianUnix
Sep 29, 2015 03:48 PM
