kinda different ???
Old May 14, 2006 | 09:42 PM
Moonrover333's Avatar
My Goodness My Guinness
kinda different ???
my friend has an FD and is thinking bout uping compresion during a rebuild and asked me if using Renesis rotors was an option. and i have no clue. i was thinking that by removing side seals it could be possible. lemme know if its possible
Old May 14, 2006 | 09:43 PM
also the more info the better a write up would own
Old May 14, 2006 | 09:52 PM
Easy_E1's Avatar
Side seals on a rotor have the same effect as a piston ring on a piston .
So if you remove them you will have no compression at all.
Renisis to my knowledge has but one side seal ,,
unlike the early 12A's which had 2. went to single side seal in 1974.
So am I confused as to what you are trying to do ?
Old May 14, 2006 | 10:24 PM
ddub's Avatar
always preoccupied.
Just tell him to go with s5 n/a rotors. They are 9.7:1 compression and will be much easier.
Old May 15, 2006 | 04:19 PM
ok i didn't mean to say side seals sorry was taling while typing kinda just mixed but he's bitchin cause you can't buy "brand new factory 13b REW rotors" i told him to go aftermarket but he says he doesn't trust other peoples stuff i dont; get it i just told him i'd ask thanx for the info. any more is good
TeslaMSI
Dec 10, 2015 01:10 AM
chadsta
Sep 20, 2015 11:00 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rx808BI
Aug 9, 2015 10:06 AM
MolecularConcept
Aug 1, 2015 03:15 PM
