View Full Version : Suspension Question
hemmingway_bg
05-08-2006, 07:01 PM
I just had koni sport shocks & H Tech springs installed. My car is now raked. I have four fingers clearance in the rear and one tight finger in the front. I have stock wheels and tires on car. My guess something done on the front to cause this but I do not know.
tiggerlee
05-08-2006, 07:06 PM
I'd be taking it back and get it checked out just to be sure. Not sure what the numbers are on the H-Techs but I recently had Koni and S-Techs installed and the drop is perfect IMO.
hemmingway_bg
05-08-2006, 07:41 PM
They are nice but do not know why rear end is up in the air. I am hoping someone hear has seen this. I bet your S Tech has more clearance in front than my H Tech springs. I wanted S Tech but chickened out and went with H Tech. I believe my set up will be very good.
tiggerlee
05-08-2006, 07:46 PM
I've got some updated pics in my sig after the install if you'd like to compare them.
Edit: Actually there's a link in that thread to my install pics....sorry.
tiggerlee
05-08-2006, 07:50 PM
Here's (http://www.rx8club.com/showpost.php?p=308468&postcount=5) what Omicron had to say about the two springs. Still haven't found any pics yet but still looking.
Winning 8
05-08-2006, 09:48 PM
did you put the rear spring to the front and the front to the rear??
hemmingway_bg
05-08-2006, 10:03 PM
I did not install myself. I asked that question though. I was told that you can not screw it up but something is wrong. That is as good of a guess as any. I would think if they could be switched I would get an inch more in front and take away an inch in the rear. I will make some calls in the morning.
staticlag
05-08-2006, 11:34 PM
That sounds like the problem.
hemmingway_bg
05-11-2006, 10:01 PM
Springs were reversed. It is easy to do.
Razz1
05-12-2006, 01:16 AM
That's what I'm thinking.
BUT you don't measure the height that way.
One way:
Go from center of axel to wheel well.
Other way and prefered method:
Measure height from groond to bottom of chassis. Ground must be flat or use a flat car lift.
If the car height is equal using method 2, but still has a noticable gap between tire and well it's the result from the design of the car from the factory to make it look like that.
Check a stock RX8.
