Mazdaspeed Flywheel
Old May 5, 2006 | 09:32 PM
teen_living_a_dream's Avatar
Mazdaspeed Flywheel
How much faster is the rx8 with this flywheel compared to stock? 0-60 times would be nice. Also, it weighs 14.7 pounds. Does anyone know how much the stock weighs?
Old May 5, 2006 | 09:37 PM
dillsrotary's Avatar
jersey fresh
it will change your 0-60 times, but you won't be able to notice it.
Old May 5, 2006 | 10:05 PM
mikefrombarrie's Avatar
Stock flywheel is 21.5lbs
My advise is, if you want a noticable gain in power get a turbo kit. Last year, I bought lightwheel rims, lighter tires, light weight pulleys, intake, racing beat ram air duct. Voltage stabilzer thinking that it would make my RX-8 faster. It did. Maybe by .2 seconds
The improvement was there, but with all the money spent on those items I should of bought the Turbo kit.
Old May 7, 2006 | 07:38 PM
I am thinking of getting the pettit racing supercharger when it comes out but usually flywheels are extremly good upgrades. On the mazda mx6 LS the stock is around 25 pounds and a 13 pound flywheel makes a 0-60 difference of about 1 second. Considering the replacement flywheel was a mx3 stock that costs $50 it was probably the best mod for the car.
Old May 7, 2006 | 08:03 PM
Winning 8's Avatar
Hot Pit
racing beat web site said stock weight 16.8 lbs, so not much different.
you better off getting the racing beat, it weight 12 lbs.
http://racingbeat.com/FRmazda4.htm
Old May 7, 2006 | 08:12 PM
NgoRX8's Avatar
so have you decided on getting the manual then?
Old May 7, 2006 | 10:50 PM
One said 21.5 lbs, RB said 16.8 lbs.
Whos right ?
*confused*
Old May 7, 2006 | 11:01 PM
QBallz's Avatar
The stock flywheel has a built in counter weight which weighs about ~4.5lbs if I recall.
So if your considering an aftermarket flywheel most of them list the weight of flywheel WITHOUT the counter weight. So most of the time you need to add ~4.5lbs to make a comparison vs. stock.
hope that helps.
Old May 8, 2006 | 07:35 AM
r0tor's Avatar
the MS flywheel has a lot of material removed from the outer portions which make its rotational inertia the same as RB's... and its rotational inertia that really matters
Old May 8, 2006 | 08:59 AM
dmp's Avatar
dmp
RX8 and a Truk....
Exactly - it's not the weight so much as where the weight is placed.
Old May 8, 2006 | 09:06 AM
DARKMAZ8's Avatar
"Call me Darkman"
what about the act one? I heard that these are the best bang for your buck..
Old May 8, 2006 | 06:10 PM
Hightshoe's Avatar
'05 Titanium 6sp
The aluminum flywheel by pettit racing claims its only 8.5lbs.
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
xAgyex
Sep 28, 2015 08:54 AM
JAYDOH
Sep 24, 2015 01:54 PM
