Mazdaspeed Dual exhaust Weight and RX8 Store highflow cat weight
Old May 2, 2006 | 08:33 PM
mikefrombarrie's Avatar
After doing search after search, it seems nobody bothered to weigh the exhaust.
so to make it easier for people who are doing a search for the weight of the exhaust I figured I would start a new thread.
Today my mazdaspeed exhaust came in, and the exhaust looks great! and the best part is it weighs 33 Lbs. Which is almost 7lbs off the stock exhaust!
Also, the Rx8 store high flow cat is 11 lbs 5 oz.
Old May 2, 2006 | 09:44 PM
BigOLundh's Avatar
#1 Legend
good info.
One of the mods should add this info to the first post in the Sticky for Exhaust information.
-hS
Old May 3, 2006 | 10:17 AM
RX-Hawk's Avatar
wtb F/I
Whats the stock cat weigh?
Old May 3, 2006 | 10:29 AM
brillo's Avatar
Go Texas Longhorns!
added
Old May 3, 2006 | 03:25 PM
The weight of the stock Cat is 23 LBS 2 oz
Old May 3, 2006 | 09:06 PM
ddub's Avatar
always preoccupied.
Not bad, the resonated/catless midpipe is 10.8 lbs. Nice to know the high flow cat isn't too much more.
Old May 5, 2006 | 08:48 PM
teen_living_a_dream's Avatar
Does the weight really make a difference in performance? The RX-8 isn't exactly built to be fast from low weight. 20 or even 7 pounds might make a difference on a Lotus Elise or Exige but I doubt it would on our cars. If you want to save weight delete your AC (unless it gets very hot where you live in the summer). Also, lighter flywheels make a huge difference on cars - especially in 1st gear. Maybe I'm wrong but it seems like the bigger pipe would be more to look at than weight for performance.
Old May 5, 2006 | 08:53 PM
ddub's Avatar
always preoccupied.
On average for most cars, every 100 lbs is ~ 0.1 sec off the quarter mile.
The AC doesn't weigh anything really.
Originally Posted by TeamRX8
LOL, the entire A/C system from the firewall forward (engine bay area) is only 18 lb. including all the pipes/hoses, condensor, idler pulley assembly, A/C drive pulley, drive belt, and bolts. Mazda didn't leave much there, the pipes/hoses are amazingly light. Probably not worth it except for the most serious efforts, but it's already out now ...
Best place to remove weight, for the most difference, would be rotational weight (ie wheels, tires, etc.). But in reality it ALL adds up. Remove 7 lbs from exhaust, 20 lbs from wheels, maybe a few from lighter tires, cut the fat in other places... it will all add up eventually. I've gotten up to 50 or 60 (can't remember) pounds so far just from exhaust and other simple things. Full interior, nothing noticeable gone, and still have stock wheels/tires.
Old May 5, 2006 | 09:23 PM
With FULL interior, my car weighs in at 2890 Lbs and thats with the Greddy turbo kit.
so my answer to your question, yes it makes a HUGE difference. When you add everything up, you would be suprised in how much weight you can take off the 8 and still have it look normal.
Old May 5, 2006 | 09:25 PM
ddub's Avatar
always preoccupied.
What else have you done to remove weight besides exhaust?
Old May 5, 2006 | 09:54 PM
I should also add that my car is a GS model which is 2960Lbs stock
Here are the 4 biggest weight savers
Stock air filter with Vfad replaced with greddy turbo air fiter saved 11 LBS 1 oz
Stock battery with plastic cover replaced with dry cell saved 26 LBS 8 oz
Washer fluid tank *Full* 14 LBS 5 oz
Jack with plastic case and emergency kit 11 LBS 1 oz
Old May 5, 2006 | 10:03 PM
ddub's Avatar
always preoccupied.
Did you actually weigh your car or are you estimating the weight of your car based on those weight savings you listed?
Old May 6, 2006 | 05:21 PM
dillsrotary's Avatar
jersey fresh
i never thought about the washer fluid, i can't believe thats freakin just about 15 pounds. Great save on the battery also
Old May 6, 2006 | 05:54 PM
in the place of the washer fluid used to be, place your light weight battery there.
I was shocked in how more responsive the steering became!
Old May 6, 2006 | 06:34 PM
rexi's Avatar
What brand is the lightweight battery and where did you get it from?
Regards
Rexi
Old May 6, 2006 | 06:44 PM
its anODYSSEY Drycell PC 680 MJT
Here's a link to their web site
http://www.odysseybatteries.com/battery/pc680mjt.htm
I have been running it for 2nd summer now and I have no problems with starting up the car. I drive my car only during the summer time, so I dont know how well the battery would perform when it gets cold. Also its around $80US so its not that expensive as the Braille battery
Old May 6, 2006 | 07:11 PM
ddub's Avatar
always preoccupied.
No answer?
dohon
Aug 1, 2015 01:46 PM
dbarber
Jul 25, 2015 01:34 PM
iwontevercare
Jul 18, 2015 09:25 AM
AussieGray
Jul 16, 2015 03:58 AM
