2006 Recall
2006 Recall
So less than a week after I drive the car home the dealer calls to tell me there's a recall for my car they need to take care of?
After several attempts to get back to them the guy tells me it's a "no start" issue and they need to check the plugs and compression.
I've checked Rosenthal's list of recalls and they have the "no start" recall listed for model years 2004-05.
Guess Mazda didn't get this resolved before mine got built-February 2006.
Anyone else with '06's experience any problems with no start?
I'm considering not taking it in at this point. The car runs great and I've had no problems at all starting the car. I'm afraid they'll try to fix one problem and create another.
Any suggestions would be greatly appreciated.
Originally Posted by mysql101
it would be difficult to explain. The new starter has more torque and spins over faster. You wouldn't be able to tell since this is your first RX-8.
Anyone else find 4 plugs in their glove box upon receiving the car??
If it sounds kind of like it's struggling to start the car up, you have the original starter - it's definitely more lethargic than normal starters. The replacement will crank just like a normal car, if not a bit stronger.
Here is the TSB info on Mazda changing plugs on 2006 RX-8 at delivery.
https://www.rx8club.com/showthread.p...86#post1329286
"Guys, how can I tell if I have the old starter?"
I believe that all RX-8 built before 5/2005 have old starter. New faster starter makes a big difference in cranking speed even if you did not have flooding issues.
as a follow-up to finding spark plugs in the glove box, it looks like our dealers failed to perform the final quality inspection at the time of delivery. depending on how long you've had the car and how it's running, you could schedule a post-delivery FQI with the dealer, call mazda for guidance or just hold onto the extra spark plugs as somebody else suggested.
The dates the flooding updates went into production are:
- Updated Engine Control Unit firmware often referred to as an ECU or PCM flash. The exact level (M, N, etc) doesn't matter, you just want them to update you car to the latest level. If you have had all the RX-8 recalls done then this has been done.
- 640 CCA battery. Comes standard on all RX-8s built after 6/1/2004.
- Upgraded starter. Comes standard on all RX-8s built after 12/1/2004.
- Improved leading spark plugs. Comes standard on all RX-8s built after 3/22/2005.
- 3/8/2006 they updated the Dealer pre-delivery procedure to include checking the battery charge level and unconditionally replacing the spark plugs.
I've got a 2004 model and it does have to crank unusually long sometimes. It does start every time though.
They (being the dealer) is supposed to install new spark plugs prior to delivery. I believe that they are not supposed to do so until they do final prep on the car as the idea is to give the owner fresh spark plugs and the ones that are in the car when it comes off the truck and used to move the car around the lot are removed and discarded??? Sent back to Mazda??? Who knows. I believe BunnyGirl said she had to wait longer for her car so the dealer could do this. Maybe she has more information.
Yeah. My "prep time" took a little longer than expected partly because they didn't remember at the time that they had to change out the plugs and do a battery test as well before I could have it. I also had "issues" with parts unavailability when it was at port so it sat there two weeks longer than originally intended. Then after it was unloaded and unpacked they were prepping it and I got a call to change the time of my appointment to sign the paperwork from 11 a.m. to 1 p.m. since they said 06s required additional prep time for a few extra steps added including changing out the plugs and testing the battery. When I got there they took me into the shop and the guy was just finishing up on my car getting all the sticky stuff and dust off.
My dealer handed me the spark plugs when I picked up the car and said change them at around 1500 miles...which happens to be now, damn the miles clock up fast..I need to stop making up excuses to drive it :D
