DIY: AEM Twin-Fire CDI Ignition Install
Old May 1, 2006 | 02:40 PM
MazdaManiac's Avatar
As many of us have discovered, the factory coils are prone to burning and failure due to heat, stress and over-voltage when used in conjunction with the Greddy E-Manage or other EMS systems.
The AEM Twin-Fire CDI (Capacitive Discharge Ignition) offers several advantages for the RX-8 over both the OEM coils and other CDI ignitions from other manufacturers.
1) It has two separate capacitors so it is able to fire the leading AND trailing plugs at the same time
2) It is very compact
3) The MSD DIS coils that I used could probably continue to work indefinately even if you set them on fire in a pot of molten lava
4) CDIs fire the plugs with considerably more voltage and longer duration (at lower RPMs) than the OEM igntion which results in a more complete burn of the combustion charge and less potential for plug fouling and a smoother idle
This installation requires a few non-typical skills including an understanding of hobbyist-level electronic circuit building. The output signal from the PCM and/or E-Manage is a positive pulse and the AEM expects to see a signal pulled to ground. This means you have to build a driver circuit. I've included this diagram which shows the schematic for the driver which includes a set of LEDs to indicate the presence of ignition signals:
The OEM coils are removed and a set of brackets are created to support the 4 new coils:
The 4 new coils are mounted to the OEM bracket and grounded with separate wires to ensure a good ground connection. The trigger and source wires (black and orange, respectively) are wired with individual connectors to mate with the AEM harness. The two leading coils have their source wires connected through a common connector to one output of the CDI and the two trailing are wired similarly to their own source.
The new assembly is mounted in the OEM position:
I mounted the AEM module just below my E-Manage in the engine bay. This is probably not an optimum location because of the heat it is exposed to, but I am lazy and I am planning on re-wiring almost all of the aftermarket electronics in the car to eliminate the rat's nest that has resulted from mulit-layer installations and experimentation over the last two years with different electronics in the car.
The three DIP switches on the AEM need to be configured to all be off. This sets the multi-strike to active, the firing to trailing edge and the frequency to every crank rev.
I fabricated a new set of plug wires. This is necessary because the OEM wires do not have the correct connector for the DIS coils. I used a Taylor 8mm "universal" kit.
Old May 1, 2006 | 04:25 PM
Working backwards:
I don't know if the OEM coils are going to be totally inadequate at any particular power level. It is possible that they are capable of putting out enough energy to keep the flame lit at elevated boost levels. However, the advantages of the CDI setup are manifold and power is but one.
Here are the items I used. Note that this assumed that an igntion harness was already in place. For those that are coming to this with an unmodified ignition/PCM system, you will need to splice the factory coil outputs at either the coil end or the PCM end.
(1) AEM 4 Channel Twin Fire Ignition PN# 30-2821
(4) MSD Blaster DIS Racing Ignition Coils PN# MSD-8230
(1) Taylor Universal Plug Wire Kit PN# TAY-73251
(2) MSD Weathertight Sealed Connectors PN# MSD-8171
(4) PNP Switching transistors (general, 20v min)
(4) 47k ohm, 1/4 watt resistors
(4) LEDs, 3v min (I used yellow for leading and green for trailing)
(1) small project board (Radio Shack)
assorted wire, connectors, solder, etc.
The brackets are cut from aluminum channel stock that is available at Home Depot or Lowe's.
The coils can be mounted in any orientation - they coontain no oil like old-fashion coils and are completely potted and sealed.
I don't know if the heat damage is necessarily arcing - it may simply be extreme heat from a combination of environment and load. But that would have to be a LOT of heat to burn the zinc-coated metal of the bracket.
Old May 1, 2006 | 04:49 PM
lurch519's Avatar
www.evoperform.com
so how does it run with the twin fire.
Old May 1, 2006 | 05:46 PM
nice job, I saw Yaw's writeup on the circuit switch
no progress on mine, just haven't had time t source the connector to fit the OE coil harness yet. It's just not my top priority at the moment. Think I may know where to source the connector though.
Old May 1, 2006 | 06:32 PM
Pretty much the same as it did without it, but with a smoother idle and faster starting.
I haven't driven it in boost yet. I posted the DIY 10 minutes after I finished the install. I'll flog it tonight. Its 100° out right now and I don't feel like driving in traffic.
Do you have a link so I can look at it?
Old May 1, 2006 | 06:47 PM
from February:
http://forum.aempower.com/forum/inde...91127#msg91127
Old May 1, 2006 | 10:36 PM
Interesting. He used field effect transistors instead of common switching transistors. I wonder why?
Same basic principle, though.
I don't have a dual-trace ocilloscope (I just have a single trace scope-meter), but it looks like the AEM with this switching circuit ends up advancing the spark a few degrees, which is bad. I think part of this is because of how quick it loads up and fires - the OEM system is slow and fires in the middle of the pulse. I'll probably have to build a buffer with a 555 timer or something similar to put the trigger a 1/2 wave later to get the timing square to avoid detonation.
Old May 2, 2006 | 01:03 AM
Beodude123's Avatar
I wonder how well it will perform at higher rpms? It might give better combustion at lower rpms, but at 9K you have a lot more energy to be keeping up with. Will it be able to keep the longer duration (I doubt multiple sparks heh) spark?
Old May 2, 2006 | 08:53 AM
brillo's Avatar
Go Texas Longhorns!
you think you'll notice any economy improvements?
Assuming someone made more powerful coils for our car, would that have the same effect as your setup?
Old May 2, 2006 | 09:15 AM
Possibly, though not likely.
Well, it will maintain a spark for 20° of crank rotation regardless of RPM.
At 9k, it won't be in multi-strike anymore because of time constraints, but it won't loose any energy either.
Old May 2, 2006 | 09:18 AM
brillo's Avatar
Go Texas Longhorns!
hows you idle now? you said its better than before, is it better than the stock idle? Do you still get vibration with the a/c on?
Old May 2, 2006 | 06:41 PM
After looking in the 2006 MSD catalog I am a bit curious as to the durability of the 8230 coil since it is a race-only coil. I wonder if the 8232, which is similar, might prove to be a bit more durable over the long-term. Plus, MSD provides the electrical measurements for the 8232 but not the 8230. Any thoughts?
CRH
The specs for the 8230 are on MSD's site. Being for "race only" I would think might make it more durable rather than less.
Conversely, I can only find a passing reference to the 8232 on MSD's site with regards to a Chrysler DIS ignition. It just looks like the 3230 repackaged with a connector rather than leads.
Old May 3, 2006 | 12:36 AM
The zinc plating is pretty thin. I do believe if you get moisture between the plate and the coil it well greatly enhance the the ability to cause a burn like that.
Old May 3, 2006 | 01:15 AM
Well, no doubt it will see moisture in that position, though it wouldn't be inundated. I'd think the heat would boil it out way before it could oxidize the plating.
That wouldn't explain the burns on the epoxy potting on the bottom of the coils, however.
Old May 4, 2006 | 01:54 AM
I recently encountered a drivability problem, appears that all four OE coils are defective, only 3300 miles on them ...
https://www.rx8club.com/series-i-tech-garage-22/breaking-up-under-part-throttle-88951/
Old Jun 4, 2006 | 10:43 AM
colin204's Avatar
any updates?
Old Jul 31, 2006 | 09:44 PM
brillo's Avatar
Go Texas Longhorns!
I was thinking today about upgraded coils and had a thought, has anyone looked into other Mazda vehicles that might have stronger coils we could use such as the Mazdaspeed6? I wonder if the connectors are the same? Just a random thought, might be worth investigating.
Old Aug 1, 2006 | 08:52 PM
Originally Posted by colin204
any updates?
not here, I've been buried at work, no spare time at all
it turned out I didn't have a coil problem afterall, car is running strong so it hasn't been a priority under the circumstances, keeping 6 spd trans from blowing up is higher on the list
Old Aug 1, 2006 | 08:56 PM
please start a thread on your work toward the tranny..
Old Aug 23, 2006 | 11:21 PM
KJ238's Avatar
Air + Fuel + Spark = Boom
If i just purchase a set of coils + a set of the weatherpack connectors.. they will work like stock right? I will not need to build a circuit of any sort?
I already have a HKS twin power for the rx-8.. I do not want to cut the connectors
Old Aug 24, 2006 | 04:34 PM
olddragger's Avatar
just better ground the factory coils and they will be ok
olddragger
Old Aug 24, 2006 | 05:25 PM
SC-ed's Avatar
olddragger
How you do that? As far as I know they are internally grounded.
Old Aug 24, 2006 | 08:21 PM
olddragger's Avatar
look at the electrical sematic in the manuel and you will see an indiviual black grounding wire from each coil. people have been spicing into that and running a ground wire from each coil to the negative post on the battery. Read the "grounding kit" thread
olddragger
Old Aug 24, 2006 | 10:47 PM
SC-ed's Avatar
olddragger
Thanks. I wasn't sure thats the way ("B" wire). Now I am.
Old Aug 25, 2006 | 08:25 AM
olddragger's Avatar
Np
od
