Which Tyres?
Old Apr 30, 2006 | 05:36 PM
9G Redline's Avatar
Trolling since 2004
When I was doing my tire search I wanted the T1Rs, but they weren't out yet. So I went with the Yokohama's. I would choose the Toyo's. My .02.
Old Apr 30, 2006 | 05:57 PM
Gomez's Avatar
Shifty Bastard.
Kall, get a hold of the latest Wheels magazine (May edition). They have just run a full on tyre test of a lot of the big brands. If I recall correctly, the TOYO's didn't score all that well.
Old Apr 30, 2006 | 06:43 PM
IZoomZoomI's Avatar
Boost needed
Yokohamas avs 100 is a good tire for the dollar, not that great in the wet though. But a lot of the tests showed avs100 as a great performer in the dry.
Kumho ecsta spts are suppose to be good also, and not pricey.
But if I had to pick from those options, eagle f1s are reputable and haven't heard a negative thing about them.
Old Apr 30, 2006 | 07:12 PM
zaglo6204's Avatar
mine's better
i have the T1-R's in 245/40 on the stock wheels, & i really enjoy them, as I have professed many a time on here. I don't have a single complaint about them: they're sticky, quiet, comfortable but responsive... it was just what I was looking for in a street tire. They are great. However, from all I've heard about the GSD3's, that would be a great choice as well. I don't think you can go wrong with either. Good luck!
Old Apr 30, 2006 | 09:08 PM
Fanman's Avatar
It really depends. if you are looking for all out performance tires to take to the track the Toyo's are not the best tire, but if you are just looking for a good street tire, that gives you good (but not great) dry & wet traction than the Toyo's are a good choice. They are also inexpensive & they have a high treadwear rating (last long time). There are other tires that do one or two things well, but they have shortcomings (price or fast tread wear). Sports Compact Car had a tire writeup last month, and they like the Toyo's as well.
Just figure out what you main concern is, prioritize & then choose. For example the Falken RT 615 has far better dry traction then the Toyo's that I got, but they have a short tread life (as most maximum traction tires do), and Ir arely track my car, and a few seconds here and there doesn't mean much to me. I wanted a quieter tire, that still holds well when I drive it aggressively on the street or a canyon run, but won't kill me when it occasionaly rains as well.
alnielsen's Avatar
When you are looking at tire tests, you want to see how they will work on your car or one close to yours. Example, don't use a test on a front drive car as the bible for a rear drive car. As I understand it, the Ford XR6 is a rear drive car, but I believe it is a bit heaver than the RX8. The Tire Rack does their testing with a BMW 330 which is closer to our configuration. I'm not going to suggest you import your tires from them. But, you can check their tests and see how they compare in their tests. They test what they sell, so not all tires are tested.
Old Apr 30, 2006 | 10:44 PM
Winning 8's Avatar
Hot Pit
toyo tires always give you feed back, even when you hit the limit they will still hold some grip. some other tires will have excellent grip but when you hit the limit you are like driving on ice.
you have to read all articals on the tires you want and see if the pro find it easy to drive not the quickest lap time or excellent traction.
a tire that talks to you are the best tire to get and save you tons of repair cost.
Old Apr 30, 2006 | 11:27 PM
Bindon's Avatar
Fire-Spewing Maniac
I just ordered a pair of Falken 615 RT....
I dunno, If I were you, id go for the F1 's
They are an incredible tire, amazing in the wet, amazing in the dry, and DAMN good treadlife.
It all depends on if you want to spend the money, because they arnt cheap.
Old May 1, 2006 | 03:27 PM
CWB's Avatar
CWB
How do the RE050A Pole Position stack up on stock rims and stock size?
Old May 3, 2006 | 04:05 AM
SymSym's Avatar
SymSym
Just remember to drive about 80-90km before you drive hard in the twisties, because you need to wear the tyre mould release compound off the tires, or otherwise the car will slide about a fair bit. Have fun and let us know how the tires go on the twisties.
Old May 3, 2006 | 07:44 PM
Tim Tam's Avatar
Hey, I was just about to start a thread the same as this one!
Have a look at this site too, they have lots of reviews from lunatics. Talk about bagging our stockers......
http://www.1010tires.com/tirereviews...e_reviews.html
Goodyears sound good:
So do Toyos:
Old May 3, 2006 | 07:48 PM
Tim Tam's Avatar
Geez, this lot bag the stockies too. So much for them being good!
http://www.tirerack.com/survey/Surve...ommentStatus=P
Old May 3, 2006 | 09:23 PM
Tim Tam's Avatar
That Wheels tyre test was testing 17s, wasn't it?
