View Full Version : Throttle Body Spacer & voltage stabilizer
2Xrotary
04-29-2006, 06:35 PM
I've been looking around at things to buy and have been looking at these 2 things on top of some others. I was just wondering if anyone has used any of these and if they are even worth the purchase.
2Xrotary
04-29-2006, 06:41 PM
B4 nething is said, YES, I searched and found that it was discussed but no one had used it yet. I'd like to know if anybody has used it or everyone decided no?
expo1
04-29-2006, 07:17 PM
And of those threads where Spacer's were discused what did you see That they cannot work? So why would someone buy one? If those $20.00 items on Ebay worked why are they not on the car from the factory?
2Xrotary
04-29-2006, 07:45 PM
its not an ebay item it is in JCWitney specifically made for the 8, not just a generic one.
expo1
04-29-2006, 09:22 PM
Popular Mechanics LINK (http://www.popularmechanics.com/automotive/new_cars_trucks/1802932.html) tested a few and they don't work. The design of the RX-8 intake and the distance of the THREE fuel injectors from the spacer makes these a waste of money. A spacer might do some good on a carburated engine since it can be placed AFTER the air/fuel are mixed. You cannot install it this way on a RX-8 and most fuel injected cars.
TeamRX8
04-30-2006, 11:54 AM
Hey kid ... want to buy some magic beans?
2Xrotary
04-30-2006, 04:11 PM
Sure, y not!
Beodude123
05-01-2006, 12:11 PM
A throttle body spacer might give you a bit of mid range on most cars, but on the RX-8, I wouldn't mess with it. Mazda engineers put a lot of effort into the intake tract getting everything tuned just right as far as plenum volume, and lengths from the throttle body to the ports. I wouldn't do anything to mess that up.
For voltage stabalizers, I have heard they can help your idle a little bit. If you do that along with grounding cords, you will at least have a stable electrical system. I wouldn't get too wound up about power gains though. Since there probably won't be any you could feel.
yiksing
05-02-2006, 04:45 AM
HAHA... you just bought a car that doesn't respond well powerwise to bolt-on parts unless you go FI or retune with Interceptor.
Spin9k
05-02-2006, 07:05 AM
Hey 2Xrotary, I might offer a bit of encouragement on the voltage stabilizer. I have a custom 400f stabilizer installed along with an custom 2058-wire, 8 point ground wire kit and Odyssey battery with a goal of maximizing the electrical system's potential.
For the whole kit the theory and my hopes are for better idle, better spark, better ECU /general electrical performance, and better top end ignition and ultimately a bit more "under the curve" HP (see: http://www.sunautomobile.com/). Lofty goals I will admit, but in an NA car everything is on the table for finding improvement.
I haven't had enough miles or track time with it to be able to offer you an authorative evaluation yet, but emperically I can say the idle is definitely silky smooth compared to the stock lumpy idle. I have found an encouraging change (electrically related I believe) that appears to potentially solve of one of the RX-8's most annoying habits, but I'd rather not risk the flames of naysayers with detail until I can offer substantive proof of theory.
Track time data logging will help document if the other mentioned benefits exist.
Bottom line, I think there is something to these 'borderline' mods.... just go for it... but don't scrimp and do it with over-the-top components and careful workmanship.
Cheers, spin :)
Razz1
02-01-2008, 11:48 PM
So, what is the feed back?
Jedi54
02-02-2008, 12:41 AM
oh boy...
stay away from them, your car will thank you
