Plugs and plug wire replacement
Old Apr 29, 2006 | 02:15 PM
BlueRenesis82's Avatar
Registered Tracker
All y'all that have done some decent track time on your 8, how often are you replacing the plugs/wires? I figure they won't last as long due to the fact that you are at high rpm operation for longer periods of time, but how long I am not sure.
Thanks for input!
Old Apr 29, 2006 | 04:12 PM
yiksing's Avatar
the giant tastetickles
You can always use a colder plug before running on the track and switched it out after the event.
Takahashi has thread on trial with different plugs on track while Richard has a thread on plugs heat ranges I think. You can search for it. As for coils many have change when their stock coils melted, in my opinion definitely change to an aftermarket if you are tracking.
Old Apr 30, 2006 | 11:36 AM
Registered Tracker
what is available for aftermarket coil packs?
Old Apr 30, 2006 | 12:43 PM
Winning 8's Avatar
Hot Pit
don't have to change wires unless you break them while changing spark plug.
I will change plugs at 20k if I track it a lot.
http://www.globaldenso.com/PLUG/racing/spec.html
I want to try these denso plugs but I only got 8k on my car. don't use the RX7 plugs because the RX8 trailing is shorter for some reason
Old Apr 30, 2006 | 12:47 PM
BigOLundh's Avatar
#1 Legend
you can get shims on the plugs to fix the shorter trailing issue. Thats how mazsport sells them.
They are significantly cheaper than the uridium rx-8 plugs
-hS
Old Apr 30, 2006 | 12:54 PM
Registered Tracker
so sticking with the stock heat is ok? nothing said about coil packs so far.....
Old Apr 30, 2006 | 01:32 PM
Winning 8's Avatar
Hot Pit
cooler plugs for track.
uZu
Dec 30, 2015 12:35 PM
PotatoCannon
Sep 6, 2015 11:48 AM
rotorsnsaabs
Aug 26, 2015 08:21 PM
MolecularConcept
Aug 5, 2015 04:43 PM
dbarber
Jul 25, 2015 01:34 PM
