questions about rotors and displacement
Old Apr 29, 2006 | 02:02 PM
joshk118's Avatar
so how much would another rotor cost if i wanted to make it a 3 rotor? and is it worth it? also, is it possible to make the motor be anything more than a 1.3? and how much would that cost?
Old Apr 29, 2006 | 02:25 PM
rotarygod's Avatar
You can't just slap on another rotor. It won't work. You'd have to have an entirely new engine and Mazda does not make a 3 rotor Renesis. This is basically like asking how hard would it be to add 2 more cylinders to a V8 to make a V10. Obviously it isn't easy and would take a new engine. Unfortunately you can not alter rotary displacement as you can a piston engine. You are pretty much stuck with a 1.3. If you are searching for more power, look to forced induction. That's your only real alternative.
Old Apr 29, 2006 | 02:27 PM
Go48's Avatar
It's not a simple matter of just adding a rotor. There are other significant modifications that must be made to the system to go to a 20B. Cost? Probably a few tens of thousands to do it right.
HINT: Use the search engine when you have questions like this. There are a number of threads discussing a 20B conversions and engine displacement. Search for 3-rotor or 20B for starters and you'll get lots of threads with good information.
Old Apr 30, 2006 | 01:27 AM
Winning 8's Avatar
Hot Pit
building the 20b renesis is easy, you just buy the e shaft from a 20b, middle plate, rotor housing, rotor apex seal, oil rings, longer 20b engin bolts.
the hard part is making a 8 port intake, exhaust and ecu, also fitting into an 8.
Old Apr 30, 2006 | 01:57 PM
rotarygod's Avatar
^None of that will work.
Old Apr 30, 2006 | 02:37 PM
Xantium's Avatar
Unregistered User
http://cgi.ebay.com/ebaymotors/3-Rot...QQcmdZViewItem
Old Apr 30, 2006 | 02:45 PM
snap-on's Avatar
That is not a Renesis engine.
Old Apr 30, 2006 | 03:34 PM
rotarygod's Avatar
^Holy crap where have you been!!!
Old Apr 30, 2006 | 04:10 PM
snap-on's Avatar
I logged in and had 137,405 new posts
I've been trying to catch up.
TJSiegrist
Sep 10, 2015 09:29 AM
jackslao
Sep 8, 2015 01:50 PM
Rupanrx
Sep 4, 2015 06:44 AM
rxwilly8
Sep 2, 2015 02:42 PM
